    ServerStatus from IP list: up or down?
    15 Posts 4 Posters 10.7k Views 3 Watching
      amanzimdwini @strawberry 3.141
      @strawberry-3.141
      Let me have a look. On first inspection, it looks perfect. I’ll let you know
        @strawberry-3.141
        Pls update your Readme to REPLACE module: 'MMM-ip" with ‘MMM-ping’ :)
        Could not get the options
                                colored: true,
                                display: 'offline',
        to work - display is still both and white only:
        (how is the display order sorted?)
        I also want to change the font size down - custom.css for me…
        Thanks, though!
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @amanzimdwini
          @amanzimdwini
          config has to look like this
              module: 'MMM-ping',
              position: 'bottom_left',
                  hosts: ['www.github.com', '192.168.1.888'],
                  colored: true,
                  display: 'offline'
          the config options neet to be part of the config section
            @strawberry-3.141
            Duh.
            Sorry. Works! Thanks
            ps - want to reduce the font size, but can;t figure out which element you are using. Any hints?
            (and the Readme was bad…)
              @amanzimdwini font is now configurable. whats bad about the readme should i add some infos?
