    Blank black screen | Noob
    44 Posts 12 Posters 63.6k Views 11 Watching
    • A
      Arod192
      So if I use Node serveronly I can see the mirror working just fine in my browser but as soon as I go into the terminal and type in pm2 start mm.sh that mirror is blank. I don’t know what else to do since this is my first time every working with a Raspberry Pi.
      I also have two MagicMirrors opening on startup
      • K
        KirAsh4 Moderator
        Confusing … you say you have two instances MM ‘opening’ at start up, and yet you are also trying to manually start it using 'pm2'? You can not run multiple instances of MM. When the first instance boots up, it binds to the configured port, and any instances after that will fail because they can’t bind to that port anymore.
        Along those same lines, you say you have two instances of MM ‘opening’ at start up, and you are trying to run it in 'serveronly' mode as well. Again, this will not work because the port is already bound to the first instance that came up. However, if after you execute the 'serveronly' setup, you don’t get any errors, that tells me you do not have any other instances running, despite you thinking there are two others running.
        So a few questions:
        • do you have MM installed in different folders?
        • are you launching them from different folders?
        • when you execute 'node serveronly', where are you typing that specifically, which folder?
        • A
          Arod192
          Alright so at startup I have two instances running, one white and one black (both are blank).
          1. I have another folder that I messed up in so I deleted everything in it and just renamed it to something else. Currently it is empty. While the other folder, MagicMirror, is a clean install.
          2. Not manually. Is there a way I can disable MagicMirror from starting automatically?
            3.I’m typing ‘node serveronly’ in the MagicMirror folder (It works fine here after I close out all other instances of MagicMirror using ‘pm2 stop mm.sdh’
          • K
            KirAsh4 Moderator
            1. you can only run two separate instances of MM is they are on different ports, and for that to work, you will need two separate installations (in separate folders) because of the config file. They can not share it.
            2. Check on 'pm2' documentations on how to delete any configured startup process
            • A
              Arod192
              Alright so I fixed the problem of the two instances opening but when I run ‘DISPLAY=:0 npm start’ It’s still blank.
              Any ideas on how to fix this? Like I said before it works when I use "node serveronly’
              • K
                KirAsh4 Moderator
                Go back to the beginning. Move your current config.js to something else, like config.js.backup. Then grab the original config.js and try running that, see if it comes up.
                You only need to set the DISPLAY=:0 if you are connecting remotely.
                • A
                  Arod192
                  Did it using the sample config and renaming it to config.js. I still get a black screen, but if I do “node serveronly” with the same files it works in my browser.
                  I’m getting no errors besides the “No helper found for module” (all of them)
                  • K
                    KirAsh4 Moderator
                    With the default config.js you get a blank screen when you try to run 'npm start' ? If so, what’s the hardware? Have you updated the OS? All variables.
                    • A
                      Arod192
                      I used the automatic installer located here, https://github.com/MichMich/MagicMirror, and followed every step.
                      I’m using a Raspberry Pi 3 Model B.
                      I’m running Raspian Jesse 4.4, Node v4.4.3.
                      The MagicMirror is up-to-date
                      A K 2 Replies Last reply
                      • A
                        amanzimdwini @Arod192
                        @Arod192
                        THIS is the setup that worked GREAT for me:
                        https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                        (Surprised KirAsh4 did not mention it. Follow it step by step; first time around will take you 30 min, but after that you will fly through it). Work. It really does.
                        K 1 Reply Last reply
                        • K
                          KirAsh4 Moderator @Arod192
                          @Arod192, that’s a rather old version of node. When you run the automatic install from MM², it installs a more recent version automatically. You shouldn’t have to do that manually.
                          • K
                            KirAsh4 Moderator @amanzimdwini
                            @amanzimdwini, I didn’t mention it … yet … because I like to figure out where the problem is, before I tell someone to start from scratch. :)
                            A 4 Replies Last reply
                            • A
                              Arod192 @KirAsh4
                              @KirAsh4 Update Node.js and I’m still having the problem
                              • A
                                Arod192 @KirAsh4
                                @KirAsh4 Okay I just changed the language from en to nl (just to see what’ll happen) and now it works!
                                But now everything is in the “nl” language but when I change it back to “en” the screen is black again
                                • A
                                  Arod192 @KirAsh4
                                  @KirAsh4 Looks like all languages work but when I change the language to en I get a black screen
                                  • A
                                    Arod192 @KirAsh4
                                    @KirAsh4 Alright I think I fixed it. What I did was I went into the translations folder and I renamed en.js to en-us.js. After that I went into the config and changed en to en-us.
                                    Reply Quote 1
                                    • R
                                      ronny3050 Module Developer
                                      @Arod192 I can confirm this is a bug. Hardcoding ‘en’ in config.js causes black-screen, however, leaving it as ’ ’ or node serveronly runs fine.
                                      • O
                                        overviewcs
                                        noob here reporting same issue and same workaround works for me.
                                        Exact Same issue and hardware and OS as poster. From a clean build, updated all before running MM auto installer as I thought I had made a mistake my first time around.
                                        “used the automatic installer located here, https://github.com/MichMich/MagicMirror, and followed every step.
                                        The MagicMirror is up-to-date”
                                        server nodeonly -works
                                        npm start -does not
                                        changing ‘en’ to ‘’ in config.js works as a workaround. It will now open in electron.
                                        • K
                                          KirAsh4 Moderator
                                          Odd bug, as I have two different rpi 3s running just fine with 'en' as the value. This makes me wonder … can any of you paste the contents of your ‘/usr/share/X11/locale/’ folder?
                                          $ sudo ls -aF /usr/share/X11/locale/
                                            smithdsl
                                            Hey Everyone,
                                            I was have the same issue. Change from ‘en’ to ’ ’ now it works.
                                            @KirAsh4 this is my “locale” folder.
                                            pi@raspberrypi:~ $ sudo ls -aF /usr/share/X11/locale/
                                            ./            fi_FI.UTF-8/       iso8859-11/  iso8859-6/    ja.SJIS/      locale.dir         sr_CS.UTF-8/   zh_CN.gb18030/    zh_TW.UTF-8/
                                            ../           georgian-academy/  iso8859-13/  iso8859-7/    km_KH.UTF-8/  microsoft-cp1251/  tatar-cyr/     zh_CN.gbk/
                                            am_ET.UTF-8/  georgian-ps/       iso8859-14/  iso8859-8/    ko/           microsoft-cp1255/  th_TH/         zh_CN.UTF-8/
                                            armscii-8/    ibm-cp1133/        iso8859-15/  iso8859-9/    koi8-c/       microsoft-cp1256/  th_TH.UTF-8/   zh_HK.big5/
                                            C/            iscii-dev/         iso8859-2/   iso8859-9e/   koi8-r/       mulelao-1/         tscii-0/       zh_HK.big5hkscs/
                                            compose.dir   isiri-3342/        iso8859-3/   ja/           koi8-u/       nokhchi-1/         vi_VN.tcvn/    zh_HK.UTF-8/
                                            el_GR.UTF-8/  iso8859-1/         iso8859-4/   ja.JIS/       ko_KR.UTF-8/  pt_BR.UTF-8/       vi_VN.viscii/  zh_TW/
                                            en_US.UTF-8/  iso8859-10/        iso8859-5/   ja_JP.UTF-8/  locale.alias  ru_RU.UTF-8/       zh_CN/         zh_TW.big5/
                                            pi@raspberrypi:~ $
                                            Thanks.
                                            • 1 / 3
