    Blank black screen | Noob
    44 Posts 12 Posters 62.7k Views 11 Watching
    • K Offline
      KirAsh4 Moderator
      And in the EN_US.UTF-8 folder? Is there stuff in there?
        smithdsl
        pi@raspberrypi:/usr/share/X11/locale/en_US.UTF-8 $ ls -aF
        ./ …/ Compose XI18N_OBJS XLC_LOCALE
        • K Offline
          KirAsh4 Moderator
          Yeah that’s odd, it’s the same on mine, so you do have en_US locale installed on the rpi. But why is MM² failing for you, when it’s working fine for me, that’s a bit of a mystery. If you don’t mind, just for grins, would you care to run through only Step 2 in this post: https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/4, specifically the Internationalization part.
          • MichMichM Offline
            MichMich
            This is a real strange situation. I tried it with different language setting, but none of them seem to cause an issue. (Even when using language: 'foobar', it just works fine.) Could one of you who is experiencing the bug, look in the developer’s console for any error messages?
              ronny3050 Module Developer @MichMich
              @MichMich I think this has something to do with electron? Because everything runs fine on server only.
              • MichMichM Offline
                MichMich
                I can’t really see how that’s affected. It’s just a variable that will be used to select the right file. I really need a log from the console to figure out what’s wrong.
                  smithdsl @MichMich
                  @MichMich How do I dump the log file?
                  • MichMichM Offline
                    MichMich
                    It’s not the node log. It’s the console log you can see in the developers tools. A screenshot (with the red error messages) is enough.
                    • MichMichM Offline
                      MichMich
                      I just pushed a possible fix to the develop branch. Please let me know if this solves the issue.
                        dejayou
                        Hi MichMich- I am using the new develop branch and whatever the fix was is not working for me. I am still getting the blank black screen. I also wasn’t able to fix it with changing the naming conventions related to the language settings that worked for others.
                        • MichMichM Offline
                          MichMich
                          In your case its probably an other issue. Could you share your config.js (don’t forget to take out sensitive info)?
                            dejayou
                            Hi MichMich,
                            Thank you for continuing to work with me on this matter. Here is the config file:
                            /* Magic Mirror Config Sample
                             * MIT Licensed.
                            var config = {
                                port: 8080,
                                language: "nl",
                                timeFormat: 24,
                                units: "metric",
                                modules: [{
                                    module: "alert"
                                    module: "wuforecast",
                                    position: "top_right", // This can be any of the regions.
                                    // Best results in left or right regions.
                                        // See ‘Configuration options’ for more information.
                                        appid: "5095830b868b90bcc31affdad4911325" //wunderground.com API key.
                                    module: "clock",
                                    position: "top_left"
                                    header: "US Holidays",
                                        calendars: [{
                                            symbol: "calendar-check-o",
                                            url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                                    module: "compliments",
                                    position: "lower_third"
                                    module: "currentweather",
                                        locationID: "4614088", //ID from bulk.openweather.org/sample/
                                    module: "weatherforecast",
                                    header: "Weather Forecast",
                                    module: "newsfeed",
                                    position: "bottom_bar",
                                        feeds: [{
                                            title: "New York Times",
                                        showSourceTitle: true,
                                        showPublishDate: true
                            if (typeof module !== "undefined") {
                                module.exports = config;
                            • MichMichM Offline
                              MichMich
                              @dejayou: could you try your magic mirror without the wuforecast module?
                                dejayou
                                That did it! Amazing thank you!
                                  spazehorst
                                  Hello @MichMich and everyone!
                                  First of all big thanks for this really cool project, my bathroom mirror is progressing well ;-)
                                  Unfortunately I cannot confirm that this issue here is solved.
                                  After succeeding to set up a Pi 1 with the serveronly feature, I ordered a Pi 3, did almost the same but maybe not thoroughly, thought I messed up, and started over from scratch:
                                  I ran the automatic installer and left the config.js.sample as it was (this was the lucky move!). I started the mirror with DISPLAY=:0 npm start. The interface shows up and gives the message: please create a config.js file.
                                  But when I do mv config.js.sample config.js and restart the mirror, I get a black screen. When I now set the language to ‘’, it works as supposed.
                                  So maybe also one of the default modules messes up (like the “wuforecast”)?
                                  Anyhow may I suggest to just set the language field blank in the config.js.sample, so that others don’t stumble upon this?
                                  Thank you and Cheers, Patrick
                                  PS:
                                  Pi 3 Model B v1.2
                                  $uname -a
                                  Linux raspberrypi 4.4.11-v7+ #888 SMP Mon May 23 20:10:33 BST 2016 armv7l GNU/Linux
                                  The only commands I ever executed after reinstall were:
                                  sudo su
                                  sudo apt-get update && apt-get dist-upgrade -y
                                  sudo apt-get install -y x11-xserver-utils unclutter matchbox vim
                                  curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                                  cd MagicMirror/
                                  MichMichM 1 Reply Last reply Reply Quote 0
                                  • MichMichM Offline
                                    MichMich @spazehorst
                                    @spazehorst could you try it with The sample config? Especially no 3rd party modules.
                                      spazehorst @MichMich
                                      @MichMich well, as I wrote above, I just renamed the sample config which is currently checkd in, never even opened it ;-) That’s why I said it must be one of those default modules…
                                      (I am sitting on this commit: 5d9d71dee8c300fede321dbafb5ff7aa79f1ea30)
                                      Cheers
                                      • MichMichM Offline
                                        @spazehorst Please try The develop branch with The latest commit.
                                          @MichMich Hi, sorry for the late reply, I could now quickly test it and with the sample config of the devel branch (commit e2ed0f5e55c132633bcbd5c7c64159c0aaced571) it works.
                                          edit: after pulling the master again, it now also works there with language: ‘en’
                                          Cheers
                                          • K Offline
                                            KirAsh4 Moderator
                                            It works with the master branch because the update was also pushed to that a few days ago. So you’ll all good. :)
                                            • 2 / 3
