    Blank black screen | Noob
    44 Posts 12 Posters 63.6k Views 11 Watching
    • MichMichM
      MichMich
      It’s not the node log. It’s the console log you can see in the developers tools. A screenshot (with the red error messages) is enough.
      • MichMichM
        MichMich
        I just pushed a possible fix to the develop branch. Please let me know if this solves the issue.
          dejayou
          Hi MichMich- I am using the new develop branch and whatever the fix was is not working for me. I am still getting the blank black screen. I also wasn’t able to fix it with changing the naming conventions related to the language settings that worked for others.
          • MichMichM
            MichMich
            In your case its probably an other issue. Could you share your config.js (don’t forget to take out sensitive info)?
              dejayou
              Hi MichMich,
              Thank you for continuing to work with me on this matter. Here is the config file:
              /* Magic Mirror Config Sample
               * MIT Licensed.
              var config = {
                  port: 8080,
                  language: "nl",
                  timeFormat: 24,
                  units: "metric",
                  modules: [{
                      module: "alert"
                      module: "wuforecast",
                      position: "top_right", // This can be any of the regions.
                      // Best results in left or right regions.
                          // See ‘Configuration options’ for more information.
                          appid: "5095830b868b90bcc31affdad4911325" //wunderground.com API key.
                      module: "clock",
                      position: "top_left"
                      header: "US Holidays",
                          calendars: [{
                              symbol: "calendar-check-o",
                      module: "compliments",
                      position: "lower_third"
                      module: "currentweather",
                          locationID: "4614088", //ID from bulk.openweather.org/sample/
                      module: "weatherforecast",
                      header: "Weather Forecast",
                      module: "newsfeed",
                      position: "bottom_bar",
                          feeds: [{
                              title: "New York Times",
                          showSourceTitle: true,
                          showPublishDate: true
              if (typeof module !== "undefined") {
                  module.exports = config;
              • MichMichM
                MichMich
                @dejayou: could you try your magic mirror without the wuforecast module?
                  dejayou
                  That did it! Amazing thank you!
                    spazehorst
                    Hello @MichMich and everyone!
                    First of all big thanks for this really cool project, my bathroom mirror is progressing well ;-)
                    Unfortunately I cannot confirm that this issue here is solved.
                    After succeeding to set up a Pi 1 with the serveronly feature, I ordered a Pi 3, did almost the same but maybe not thoroughly, thought I messed up, and started over from scratch:
                    I ran the automatic installer and left the config.js.sample as it was (this was the lucky move!). I started the mirror with DISPLAY=:0 npm start. The interface shows up and gives the message: please create a config.js file.
                    But when I do mv config.js.sample config.js and restart the mirror, I get a black screen. When I now set the language to ‘’, it works as supposed.
                    So maybe also one of the default modules messes up (like the “wuforecast”)?
                    Anyhow may I suggest to just set the language field blank in the config.js.sample, so that others don’t stumble upon this?
                    Thank you and Cheers, Patrick
                    PS:
                    Pi 3 Model B v1.2
                    $uname -a
                    Linux raspberrypi 4.4.11-v7+ #888 SMP Mon May 23 20:10:33 BST 2016 armv7l GNU/Linux
                    The only commands I ever executed after reinstall were:
                    sudo su
                    sudo apt-get update && apt-get dist-upgrade -y
                    sudo apt-get install -y x11-xserver-utils unclutter matchbox vim
                    curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                    cd MagicMirror/
                    MichMichM 1 Reply Last reply Reply Quote 0
                    • MichMichM
                      MichMich @spazehorst
                      @spazehorst could you try it with The sample config? Especially no 3rd party modules.
                        spazehorst @MichMich
                        @MichMich well, as I wrote above, I just renamed the sample config which is currently checkd in, never even opened it ;-) That’s why I said it must be one of those default modules…
                        (I am sitting on this commit: 5d9d71dee8c300fede321dbafb5ff7aa79f1ea30)
                        Cheers
                        • MichMichM
                          @spazehorst Please try The develop branch with The latest commit.
                            @MichMich Hi, sorry for the late reply, I could now quickly test it and with the sample config of the devel branch (commit e2ed0f5e55c132633bcbd5c7c64159c0aaced571) it works.
                            edit: after pulling the master again, it now also works there with language: ‘en’
                            Cheers
                            • K
                              KirAsh4 Moderator
                              It works with the master branch because the update was also pushed to that a few days ago. So you’ll all good. :)
                              • axellejamousA
                                axellejamous
                                Hello!
                                I was wondering if any of you could help me.
                                I’m basically having the exact same issue as this topic, except the “nl to en” fix isn’t working for me. I’m running the MM with it’s basic config file.
                                Runs fine on serveronly, but get a black screen on npm start.
                                I’ve updated everything from my pi to my os to my node modules, but nothing seems to be working. There also don’t seem to be any errors.
                                  bhepler Module Developer @axellejamous
                                  @axellejamous I want to verify a couple of things, just to be sure.
                                  1. You’re running npm start on the Pi itself, not via an SSH connection from another computer.
                                  2. Your monitor is hooked up to the Pi via the HDMI port.
                                  axellejamousA 1 Reply Last reply Reply Quote 0
                                  • axellejamousA
                                    axellejamous @bhepler
                                    @bhepler I was! But I manages to fix the issue.
                                    When checking npm versions I saw that electron was ver 1.8.1
                                    I ended up rolling back to 1.7.9 and it works perfectly!
                                    Have no idea why 1.8.1 results in a black screen though.
                                    A 1 Reply Last reply Reply Quote 1
                                    • A
                                      abetterway @axellejamous
                                      @axellejamous I just ran into this black screen issue too.
                                      I figured out that the local electron display will only work if the config.js contains:
                                        address: "localhost"
                                      I was running with the following and getting a black screen
                                        address: "::"
                                      Instead of using the built in display I am going to launch chromium myself in --kiosk mode. I need the MM to listen on all interfaces so I can see and debug from a separate machine.
                                      • 2 / 3
