    Blank black screen | Noob
    44 Posts 12 Posters 59.6k Views 11 Watching
    • MichMichM Offline
      MichMich
      In your case its probably an other issue. Could you share your config.js (don’t forget to take out sensitive info)?
        dejayou
        Hi MichMich,
        Thank you for continuing to work with me on this matter. Here is the config file:
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
            port: 8080,
            language: "nl",
            timeFormat: 24,
            units: "metric",
            modules: [{
                module: "alert"
                module: "wuforecast",
                position: "top_right", // This can be any of the regions.
                // Best results in left or right regions.
                    // See ‘Configuration options’ for more information.
                    appid: "5095830b868b90bcc31affdad4911325" //wunderground.com API key.
                module: "clock",
                position: "top_left"
                header: "US Holidays",
                    calendars: [{
                        symbol: "calendar-check-o",
                        url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                module: "compliments",
                position: "lower_third"
                module: "currentweather",
                    locationID: "4614088", //ID from bulk.openweather.org/sample/
                module: "weatherforecast",
                header: "Weather Forecast",
                module: "newsfeed",
                position: "bottom_bar",
                    feeds: [{
                        title: "New York Times",
                    showSourceTitle: true,
                    showPublishDate: true
        if (typeof module !== "undefined") {
            module.exports = config;
        • MichMichM Offline
          MichMich
          @dejayou: could you try your magic mirror without the wuforecast module?
            dejayou
            That did it! Amazing thank you!
              spazehorst
              Hello @MichMich and everyone!
              First of all big thanks for this really cool project, my bathroom mirror is progressing well ;-)
              Unfortunately I cannot confirm that this issue here is solved.
              After succeeding to set up a Pi 1 with the serveronly feature, I ordered a Pi 3, did almost the same but maybe not thoroughly, thought I messed up, and started over from scratch:
              I ran the automatic installer and left the config.js.sample as it was (this was the lucky move!). I started the mirror with DISPLAY=:0 npm start. The interface shows up and gives the message: please create a config.js file.
              But when I do mv config.js.sample config.js and restart the mirror, I get a black screen. When I now set the language to ‘’, it works as supposed.
              So maybe also one of the default modules messes up (like the “wuforecast”)?
              Anyhow may I suggest to just set the language field blank in the config.js.sample, so that others don’t stumble upon this?
              Thank you and Cheers, Patrick
              PS:
              Pi 3 Model B v1.2
              $uname -a
              Linux raspberrypi 4.4.11-v7+ #888 SMP Mon May 23 20:10:33 BST 2016 armv7l GNU/Linux
              The only commands I ever executed after reinstall were:
              sudo su
              sudo apt-get update && apt-get dist-upgrade -y
              sudo apt-get install -y x11-xserver-utils unclutter matchbox vim
              curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
              cd MagicMirror/
              MichMichM 1 Reply Last reply Reply Quote 0
              • MichMichM Offline
                MichMich @spazehorst
                @spazehorst could you try it with The sample config? Especially no 3rd party modules.
                  spazehorst @MichMich
                  @MichMich well, as I wrote above, I just renamed the sample config which is currently checkd in, never even opened it ;-) That’s why I said it must be one of those default modules…
                  (I am sitting on this commit: 5d9d71dee8c300fede321dbafb5ff7aa79f1ea30)
                  Cheers
                  • MichMichM Offline
                    @spazehorst Please try The develop branch with The latest commit.
                      @MichMich Hi, sorry for the late reply, I could now quickly test it and with the sample config of the devel branch (commit e2ed0f5e55c132633bcbd5c7c64159c0aaced571) it works.
                      edit: after pulling the master again, it now also works there with language: ‘en’
                      Cheers
                      • KirAsh4K Offline
                        KirAsh4 Moderator
                        It works with the master branch because the update was also pushed to that a few days ago. So you’ll all good. :)
                        • 4 / 5
