    Worldclock & Currency
    12 Posts 4 Posters 5.1k Views 4 Watching
    • yawnsY Offline
      yawns Moderator @Guest
      @Sean
      In fact there were some feature requests in the past, but I am more than busy with building our house and training our dog to pass an important test (which drastically reduces dog taxes).
      It would be no big deal to add several bases and currencies you would like to see with this base. By September I should have more time.
      Until then you can simply add the module several times with different bases.
      • ? Offline
        A Former User
        Thanks for everyone.
        CurrencyExchange module works as good as my thought. thanks again.
        I made my first MM module for world clock by myself.
        https://github.com/eouia/worldclock
        It was also my first JS programming and even my first GIT usage. hahahaha. :D
        Very interesting experience.
        yawnsY 1 Reply Last reply Reply Quote 1
        • yawnsY Offline
          @Sean
          Glad to hear you like the module =)
          • N Offline
            nobita @yawns
            @Sean ,What Happen after install module only " Loading…" display
            I think your module apikey not use in config (may be mistake)
            • ? Offline
              A Former User @nobita
              @nobita what apiKey? what module? Are you saying about “MMM-CurrencyExchange”? It is not mine.
              yawnsY 1 Reply Last reply Reply Quote 0
              • yawnsY Offline
                @sean said in Worldclock & Currency:
                MMM-CurrencyExchange never required an apiKey, but looking at the source fixer.io they seem to require an apiKey nowadays. Looking further I see raised issues on gitHub I never even noticed. My bad! I will try to fix it this evening, let’s hope my daughter does not intercept my plan :D
                  ryck Module Developer @yawns
                  @yawns You can always use https://exchangeratesapi.io/ if you don’t want to make people get an apiKey…
                  yawnsY 1 Reply Last reply Reply Quote 2
                  • yawnsY Offline
                    yawns Moderator @ryck
                    @ryck said in Worldclock & Currency:
                    Thanks for the heads up. I updated the module to use the new source instead.
