    • Search
    MagicMirror² v2.24.0 is available! For more information about this release, check out this topic.
    MMM Facial Recognition - not working
    Troubleshooting
    • X
      xchribiza last edited by
      Hi to all!
      I am looking for your help.
      I am a newbie and i am setting up my magic mirror
      I use a usbcamera witch i have managed to get it to work to capture my photos for profile and face recognition but when i start the magic mirror it doesn’t turn on ( i have set to “true” the useUSBCAM at config)
      I also get these errors on startup .
      (Launching application.
      ERROR! Could not find main module js file.
      Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
      GET_WUNDERGROUND
      Create new news fetcher for url: http://feeds.feedburner.com/aek365gr-all?format=xml - Interval: 300000
      Create new news fetcher for url: http://www.sport24.gr/latest/?widget=rssfeed&view=feed&contentId=174866 - Interval: 300000
      [MMM-Facial-Recognition] Facerecognition started…
      [MMM-Facial-Recognition] Loading training data…
      [MMM-Facial-Recognition] ALGORITHM: LBPH
      Whoops! There was an uncaught exception…
      { Error: OpenCV Error: Unspecified error (File can’t be opened for writing!) in load, file /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/contrib/src/facerec.cpp, line 325
      Traceback (most recent call last):
      File “modules/MMM-Facial-Recognition/facerecognition/facerecognition.py”, line 59, in
      model.load(config.get(“trainingFile”))
      cv2.error: /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/contrib/src/facerec.cpp:325: error: (-2) File can’t be opened for writing! in function load
      at PythonShell.parseError (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_modules/python-shell/index.js:190:17)
      at terminateIfNeeded (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_modules/python-shell/index.js:98:28)
      at ChildProcess. (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_modules/python-shell/index.js:88:9)
      at emitTwo (events.js:106:13)
      at ChildProcess.emit (events.js:191:7)
      at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
      executable: ‘python’,
      options: null,
      script: ‘modules/MMM-Facial-Recognition/facerecognition/facerecognition.py’,
      args: [ ‘{“recognitionAlgorithm”:1,“lbphThreshold”:50,“fisherThreshold”:250,“eigenThreshold”:3000,“useUSBCam”:true,“trainingFile”:“/modules/MMM-Facial-Recognition/training.xml”,“interval”:2,“logoutDelay”:15,“users”:[“Christos”],“defaultClass”:“default”,“everyoneClass”:“everyone”,“welcomeMessage”:true}’ ],
      exitCode: 1 }
      MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?)
      Please I would appreciate any help
      thank you in advance
      strawberry 3.141 1 Reply Last reply Reply Quote 0
      • strawberry 3.141
        strawberry 3.141 Project Sponsor Module Developer @xchribiza last edited by
        @xchribiza sounds like missing file permission
        X 1 Reply Last reply Reply Quote 0
        • D
          detuma last edited by
          Is your training file in /modules/MMM-Facial-Recognition/ ? (it is probably in /modules/MMM-Facial-Recognition-Tools/ ), check the path again, and do some change in your config.js
          • X
            xchribiza @strawberry 3.141 last edited by
            @strawberry-3.141 How do I fix this ?? Any idea ?
            • X
              xchribiza @detuma last edited by
              @detuma I have copied the training.xlm to both locations (tools etc) and checked with the both location in config.js
              nothing happended.
              It seems like the camera is not opening (i use a usbcamera)
              • D
                I’m pretty sure you still wrote a wrong path, check this post https://forum.magicmirror.builders/topic/62/face-recognition-file-can-t-be-opened-for-writing/5
