    MMM-uber and MMM-lyft
    40 Posts 8 Posters 31.5k Views 7 Watching
    • O Offline
      onetwankyfive @kal
      @kal Its to hacked together to post and it cuts off the module above it without adding a blank space header to your module… I just set top margin to -40px.
      • kalK Offline
        kal @shashank
        @shashank it’s a typo in the documentation but 'POOL' should work.
          shashank @kal
          @kal no luck, still Uber X default
          kalK 1 Reply Last reply Reply Quote 0
          • kalK Offline
            kal @shashank
            @shashank Can you post the mmm-uber portion of your config file? It’s working for me.
            You may want to delete and re-download the repo in your Modules folder. I’ve pushed some changes since the first post.
              shashank @kal
              @kal hi, I deleted and reloaded the modules, still same issue, below my config
              module: ‘MMM-uber’,
              position: ‘top_left’,
              header: ‘Uber (DC)’,
              ride_type: ‘pool’,
              lat: XX.XXXX, // use your exact pickup loaction
              lng: XX.XXXX, // use your exact pickup loaction
              uberServerToken:
              • kalK Offline
                kal @shashank
                @shashank like I mentioned, your ride type needs to be capitalized. Use 'POOL' like shown below. Also, the ride_type: needs to be placed into the config portion. You can put it under the uberServerToken.
                			module: 'MMM-uber',
                			position: 'top_left',
                			header: 'Uber (DC)',
                				uberServerToken: 'your_uberServerToken',
                				ride_type: 'POOL'
                S 3 Replies Last reply Reply Quote 0
                  shashank @kal
                  @kal said in MMM-uber and MMM-lyft:
                  ride_type: 'POOL
                  hi, i did the changes now it displays as “POOL in null min”
                  module: ‘MMM-uber’,
                  lat: xx.xxxx, // use your exact pickup loaction
                  lng: xx.xxxx, // use your exact pickup loaction
                  uberServerToken: ’ ',
                  ride_type: ‘POOL’
                  • kalK Offline
                    kal @shashank
                    @shashank That means that no uber pool is available in your area. This is an error case that I haven’t dealt with explicitly.
                    To confirm this is the error, you need to look at the console log. You’ll see the ProcessUber returns ‘Time’ and then an object. Go through the object and look for pool as a ride type. It should look like this:
                    You can also try to order an uber pool on your phone to confirm that one is not available.
                      shashank @kal
                      @kal
                      ok, Thank you , let me check
                        shashank @kal
                        @kal hi, i tried changing the location even then POOL not working, i mobile same location POOL is working
                        • 3 / 4
