    MMM-uber and MMM-lyft
    40 Posts 8 Posters 35.5k Views 7 Watching
      shashank @kal
      @kal Singapore
        Sarb
        @kal Thank you very much for creating these modules! For some reason I am unable to get both the Uber or Lyft module to return any results. The only thing displayed is their respective logos and “Checking for Uber/Lyft status…” messages. It’s been displaying this for hours now. Is there anything special I need to do once I have registered as a developer and gotten the server tokens?
        kalK 1 Reply Last reply Reply Quote 0
        • kalK Offline
          kal @Sarb
          @Sarb Can you post your config file and log? It sounds like a REST API failure…
            Sarb @kal
            @kal Please see my config entries below:
            		module: 'MMM-uber',
            		position: 'top_right',
            		header: 'Uber & Lyft',
            			lat: <>,
            			lng: <>,
            			uberServerToken: '<>',
            		module: 'MMM-uber',
            			lat: <>,
            			lng: <>,
            			ride_type: 'uberXL',
            		module: 'MMM-lyft',
            			lat: <>,
            			lng: <>,
            			clientID: '<>',
            			clientSecret: '<>',
            Sorry for being such a noob but I am not sure where to pull my log file from. I ran a quick search and I read that it is supposed to be in a folder named pm2 in my pi folder but I do not see a folder with that name (even when showing hidden items). I did however notice this in my console window:
            Whoops! There was an uncaught exception…
            TypeError: Cannot read property ‘statusCode’ of undefined
            at Request._callback (/home/pi/MagicMirror/modules/MMM-lyft/node_helper.js:43:97)
            at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:188:22)
            at emitOne (events.js:96:13)
            at Request.emit (events.js:191:7)
            at Auth.basic (/home/pi/MagicMirror/node_modules/request/lib/auth.js:24:18)
            at Auth.onRequest (/home/pi/MagicMirror/node_modules/request/lib/auth.js:137:23)
            at Request.auth (/home/pi/MagicMirror/node_modules/request/request.js:1360:14)
            at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:378:10)
            at new Request (/home/pi/MagicMirror/node_modules/request/request.js:130:8)
            at request (/home/pi/MagicMirror/node_modules/request/index.js:54:10)
            • kalK Offline
              kal @Sarb
              @Sarb your config looks good, but I want to see your log before I open an issue.
              We need to view your JavaScript console. Access the mirror directly or whitelist the IP of another computer to access via a browser. Then, go to https://IP.of.Raspberry.Pi:8080 in Chrome and View>Developer>JavaScript Console.
              See this this thread for more info.
                Sarb @kal
                @kal Please see below:
                Filtering for Uber
                Filtering for Lyft
                • kalK Offline
                  kal @Sarb
                  @Sarb Two things:
                  1. Make sure that your uberServerToken and clientID/clientSecret don’t contain the greater/less than characters in your config (these things: <>). Those are placeholders. For example, if your uberServerToken is abc123 then the line in your config should read uberServerToken: 'abc123', without those characters.
                  2. If that doesn’t work, can you go into the .js file for uber and un-comment this line. Then post the log. You should be looking for one that says ERROR...
                    Sarb @kal
                    @kal
                    1. I can confirm my uberServerToken and clientID/clientSecret don’t contain the greater/less than characters in my config file. I only used those so I wasn’t displaying them. :)
                    2. Please see screenshot below:
                    • kalK Offline
                      kal @Sarb
                      @Sarb from the docs it looks like you supplied an invalid code. Can you regenerate your token and try again?
                      Also, what country are you in?
                        Sarb @kal
                        @kal Looks like regenerating the uber server token did the trick! Not sure how it could have been invalid the first time since I copy and pasted it. Thank you very much for your help, however I am still seeing the same issue with the Lyft module. I refreshed my Client Secret and copied the new string, but it did not fix anything. I also commented out the same line in the lyft js file. Screenshot below, I do not see any errors. I am located in Southern California if that helps.
                        • kalK Offline
                          kal @Sarb
                          @Sarb Are you sure you uncommented / that’s all of the Lyft outputs? There should be more.
                            Sarb @kal
                            @kal I can confirm that I uncommented line 143 of the MMM-Lyft.js file. Could the issue possibly be tied to the error I sent earlier that I see in my console window? Copying once more so it is easier to find.
                            • kalK Offline
                              kal @Sarb
                              @Sarb you’re encountering an access error and that exception is a symptom, not a cause. My advice would be to regenerate Lyft ID and Secret for your config or perhaps register as a new user and get a new ID.
                                Sarb @kal
                                @kal Thank you for all your help. After a bunch of troubleshooting I was finally able to notice that I was using “clientID” instead of “clientId” in my config file. It is working now.
                                • kalK Offline
                                  kal @Sarb
                                  @Sarb yea that was a confusing thing for me to do (I’ll consider changing in the next version). In the future make sure to just copy and paste from the GitHub page.
                                  Glad you’re all sorted out!
                                  • twosquirrelsT Offline
                                    twosquirrels
                                    My MMM-uber has been fine for weeks, but just says “uberX in undefined min” for the last couple of days. Anybody else have this issue?
                                      jdahli1 @twosquirrels
                                      @twosquirrels I’m having the same issue as you. An issue with the Uber API perhaps?
                                      twosquirrelsT 1 Reply Last reply Reply Quote 0
                                        twosquirrels @jdahli1
                                        @jdahli1 I tried deleting my uber api key and generating a brand new key and it didn’t help. I reinstalled my magicmirror from scratch and it didn’t help. The API must have changed.
                                          twosquirrels
                                          I completely deleted the uber module folder and reinstalled. That fixed it. I could have sworn I tried that, but it worked just now.
                                            twosquirrels
                                            I now get this bizarre issue where Lyft shows the times in minutes down to 15 decimal places. Anybody else?
