    MMM-uber and MMM-lyft
    40 Posts 8 Posters 36.3k Views 7 Watching
    • kalK
      kal @Sarb
      @Sarb Are you sure you uncommented / that’s all of the Lyft outputs? There should be more.
        Sarb @kal
        @kal I can confirm that I uncommented line 143 of the MMM-Lyft.js file. Could the issue possibly be tied to the error I sent earlier that I see in my console window? Copying once more so it is easier to find.
        Whoops! There was an uncaught exception…
        TypeError: Cannot read property ‘statusCode’ of undefined
        at Request._callback (/home/pi/MagicMirror/modules/MMM-lyft/node_helper.js:43:97)
        at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:188:22)
        at emitOne (events.js:96:13)
        at Request.emit (events.js:191:7)
        at Auth.basic (/home/pi/MagicMirror/node_modules/request/lib/auth.js:24:18)
        at Auth.onRequest (/home/pi/MagicMirror/node_modules/request/lib/auth.js:137:23)
        at Request.auth (/home/pi/MagicMirror/node_modules/request/request.js:1360:14)
        at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:378:10)
        at new Request (/home/pi/MagicMirror/node_modules/request/request.js:130:8)
        at request (/home/pi/MagicMirror/node_modules/request/index.js:54:10)
        kalK 1 Reply Last reply
        • kalK
          kal @Sarb
          @Sarb you’re encountering an access error and that exception is a symptom, not a cause. My advice would be to regenerate Lyft ID and Secret for your config or perhaps register as a new user and get a new ID.
            Sarb @kal
            @kal Thank you for all your help. After a bunch of troubleshooting I was finally able to notice that I was using “clientID” instead of “clientId” in my config file. It is working now.
            • kalK
              kal @Sarb
              @Sarb yea that was a confusing thing for me to do (I’ll consider changing in the next version). In the future make sure to just copy and paste from the GitHub page.
              Glad you’re all sorted out!
              • twosquirrelsT
                twosquirrels
                My MMM-uber has been fine for weeks, but just says “uberX in undefined min” for the last couple of days. Anybody else have this issue?
                J 1 Reply Last reply
                  jdahli1 @twosquirrels
                  @twosquirrels I’m having the same issue as you. An issue with the Uber API perhaps?
                  twosquirrelsT 1 Reply Last reply
                  • twosquirrelsT
                    twosquirrels @jdahli1
                    @jdahli1 I tried deleting my uber api key and generating a brand new key and it didn’t help. I reinstalled my magicmirror from scratch and it didn’t help. The API must have changed.
                    • twosquirrelsT
                      twosquirrels
                      I completely deleted the uber module folder and reinstalled. That fixed it. I could have sworn I tried that, but it worked just now.
                      • twosquirrelsT
                        twosquirrels
                        I now get this bizarre issue where Lyft shows the times in minutes down to 15 decimal places. Anybody else?
                        • F
                          futurahem
                          Hi all. Is this still working?
                          I installed the module as directed and added the module to config. I moved some stuff around to confirm it was actually affecting the mirror but the Uber module doesn’t appear no matter that I do.
                          In the past when I had an error the place holder would pop up but It’s loading just fine just not this module (Uber in particular).
                          • F
                            futurahem
                            Right after posting I figured it out. When you download/clone the git it has a -master at the end. In the config the module name is “mmm-uber” and as that wasn’t matching up to the folder in the modules folder (in case anyone else experiences this) it wasn’t coming up.
                              menanr
                              does the Uber and Lyft modules still work?
