    MMM-ModuleScheduler & MMM-Instagram
    1 Posts 1 Posters 911 Views 1 Watching
    • V Offline
      vwillcox
      Hi, I have set this module to be hidden, but it is not being picked up in the scheduler:
      Starting MagicMirror: v2.1.2
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-WatchDog
      Module helper loaded: MMM-ModuleScheduler
      Module helper loaded: MMM-Instagram
      All module helpers loaded.
      Server started ...
      Connecting socket for: MMM-WatchDog
      Starting module helper: MMM-WatchDog
      Connecting socket for: MMM-ModuleScheduler
      Starting node helper for: MMM-ModuleScheduler
      Connecting socket for: MMM-Instagram
      Starting node_helper for module [MMM-Instagram]
      Starting module: newsfeed
      Launching application.
      WatchDog started. Maximum timeout: 10s.
      MMM-ModuleScheduler is removing all scheduled jobs
      MMM-ModuleScheduler received CREATE_MODULE_SCHEDULE
      MMM-ModuleScheduler is scheduling currentweather using "5-59/10 * * * *" and "0-59/10 * * * *" with dim level undefined
      MMM-ModuleScheduler is hiding currentweather
      MMM-ModuleScheduler has scheduled currentweather
      MMM-ModuleScheduler will next show currentweather at Sun Jul 09 2017 18:45:00 GMT+0100 (BST)
      MMM-ModuleScheduler will next hide currentweather at Sun Jul 09 2017 18:50:00 GMT+0100 (BST)
      MMM-ModuleScheduler is scheduling weatherforecast using "5-59/10 * * * *" and "0-59/10 * * * *" with dim level undefined
      MMM-ModuleScheduler is hiding weatherforecast
      MMM-ModuleScheduler has scheduled weatherforecast
      MMM-ModuleScheduler will next show weatherforecast at Sun Jul 09 2017 18:45:00 GMT+0100 (BST)
      MMM-ModuleScheduler will next hide weatherforecast at Sun Jul 09 2017 18:50:00 GMT+0100 (BST)
      MMM-ModuleScheduler is scheduling newsfeed using "5-59/10 * * * *" and "0-59/10 * * * *" with dim level undefined
      MMM-ModuleScheduler is hiding newsfeed
      MMM-ModuleScheduler has scheduled newsfeed
      MMM-ModuleScheduler will next show newsfeed at Sun Jul 09 2017 18:45:00 GMT+0100 (BST)
      MMM-ModuleScheduler will next hide newsfeed at Sun Jul 09 2017 18:50:00 GMT+0100 (BST)
      Create new news fetcher for url: http://newsrss.bbc.co.uk/rss/newsonline_uk_edition/front_page/rss.xml - Interval: 300000
      MMM-ModuleScheduler is sending SHOW_MODULE to module_6_currentweather
      MMM-ModuleScheduler will next send SHOW_MODULE to module_6_currentweather at Sun Jul 09 2017 18:55:00 GMT+0100 (BST) based on "5-59/10 * * * *"
      MMM-ModuleScheduler is sending SHOW_MODULE to module_7_weatherforecast
      MMM-ModuleScheduler will next send SHOW_MODULE to module_7_weatherforecast at Sun Jul 09 2017 18:55:00 GMT+0100 (BST) based on "5-59/10 * * * *"
      MMM-ModuleScheduler is sending SHOW_MODULE to module_8_newsfeed
      MMM-ModuleScheduler will next send SHOW_MODULE to module_8_newsfeed at Sun Jul 09 2017 18:55:00 GMT+0100 (BST) based on "5-59/10 * * * *"
      MMM-ModuleScheduler is sending HIDE_MODULE to module_6_currentweather
      MMM-ModuleScheduler will next send HIDE_MODULE to module_6_currentweather at Sun Jul 09 2017 19:00:00 GMT+0100 (BST) based on "0-59/10 * * * *"
      MMM-ModuleScheduler is sending HIDE_MODULE to module_7_weatherforecast
      MMM-ModuleScheduler will next send HIDE_MODULE to module_7_weatherforecast at Sun Jul 09 2017 19:00:00 GMT+0100 (BST) based on "0-59/10 * * * *"
      MMM-ModuleScheduler is sending HIDE_MODULE to module_8_newsfeed
      MMM-ModuleScheduler will next send HIDE_MODULE to module_8_newsfeed at Sun Jul 09 2017 19:00:00 GMT+0100 (BST) based on "0-59/10 * * * *"
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
              port: 8080,
              ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.0.17"], // Set [] to allow all IP addresses
              language: "en",
              timeFormat: 24,
              units: "metric",
                              module: 'MMM-WatchDog',
                              module: "alert",
                              module: 'MMM-ModuleScheduler'
                              module: "updatenotification",
                              position: "top_bar"
                              module: "clock",
                              module: "MMM-Instagram",
                              classes: "scheduler",
                                      access_token: "...",
                                      count: "35",
                                      min_timestamp: "0",
                                      animationSpeed: "2500",
                                      updateInterval: "12500",
                                      module_schedule: {from: '0-59/10 * * * *',  to: '5-59/10 * * * *'}
                              module: "currentweather",
                              classes: 'scheduler',
                                      module_schedule: {from: '5-59/10 * * * *',  to: '0-59/10 * * * *'},
                                      locationID: "2652618",  //ID from http://www.openweathermap.org/help/city_list.txt
                                      appid: "..."
                              module: "weatherforecast",
                              header: "Weather Forecast",
                                      appid: "...",
                                      maxNumberOfDays: '4',
                              module: "newsfeed",
                              position: "top_bar",
                                      feeds: [
                                                      title: "BBC News",
                                                      url: "http://newsrss.bbc.co.uk/rss/newsonline_uk_edition/front_page/rss.xml"
                                      showSourceTitle: false,
                                      showPublishDate: false,
                                      wrapTitle: false,
                                      ignoreOldItems: true,
      I am scratching my head.
      Thanks.
