    How do notifications work?
    notificationsbuttonprofileswticher
    11 Posts 4 Posters 10.1k Views 4 Watching
      j.e.f.f Project Sponsor Module Developer @Sruc91
      @Sruc91 I’m doing something similar. Take a look at the MMM-Buttons module to see how to capture the button press and send notifications, and then take a look at MMM-Profile switcher to see how it receives notifications.
      In my case, I modified MMM-ProfileSwitcher to receive a “CYCLE_PROFILE” notification that cycles through a list of configured profiles. PM me and I can send you my modified version.
        Sruc91
        @Sean That does make sense, thank you. In some modules’ descriptions they are just mentioned but no indication on how one should use them.
        @j-e-f-f So I see that in the MMM-Buttons module the notifications are defined in the config file and you can use the needed payload to send information.
        So if I understand correctly, if I send a notification from MMM-Buttons like so:
        this.sendNotification('CURRENT_PROFILE', 'DESIRED_PROFILE_NAME_HERE');
        Do I just send the desired notification with the payload of the desired profile and the ProfileSwitcher will understand it?
        ? J 2 Replies Last reply Reply Quote 0
        • ? Offline
          A Former User @Sruc91
          @Sruc91 as i know, you are right.
          Or you can build your ‘translator’ module which send CURRENT_PROFILE message when BTN_PRESSED message is coming between btn module and prflswtchr module… Its better to keep original legacy codes.
            @Sruc91 well yeah, but the way MMM-Buttons works, it would send the same payload each time. So if you configured the button press to send the notification ‘CURRENT_PROFILE’ with the payload ‘Jeff’, each button press would be a request to show Jeff’s profile.
            So you need something that always receives the same notification/payload pair to do something different each time with it. That’s what my modification to ‘MMM-ProfileSwitcher’ does, or you can do as @Sean says and write another module to keep track of which profile is next and relay the ‘CURRENT_PROFILE’ notification to the MMM-ProfileSwitcher.
              Sruc91
              @j-e-f-f That makes sense, thank you very much.
              Is there any way that I can track those notifications? Like for example, if I send a notification with the MMM-Buttons, is it registered anyway that I can check?
              J cowboysdudeC 2 Replies Last reply Reply Quote 0
                @Sruc91 you’ll see output in Electron’s console when the event is broadcast.
                • cowboysdudeC Offline
                  cowboysdude Module Developer @Sruc91
                  @Sruc91
                  console.log(your output);
