    Updating Compliments using a spreadsheet
    14 Posts 4 Posters 5.0k Views 4 Watching
      sdetweil @emrah_asl
      @emrah_asl well, the problem is coming up w something u have the skills to do.
        sdetweil
        so, thinking more.
        do you have a js routine that will download the sheet in json and convert to the proper format now? you would execute it with
        node ???whatever your script name is???
        if so, you could add it to the installers/mm.sh script that is used by pm2 to start mm.
        this way every time mm is started, you would download the new compliments file sheet and convert it
        • E Offline
          emrah_asl
          Hi @sdetweil ,
          Thanks for reply.
          my code in node_helper.js (under compliments folder) are creating file on root normally when you start mm with npm start
          The problems are,
          1 - I need to change save folder not root side, it needs to be under compliements folder, so I change this but not works
           var fs = require('fs');
                  fs.writeFile("modules/default/compliments/remotefile.json", compliments, function(err) {
                      if (err) {
                          return console.log(err);
                      console.log("The file was saved!");
          1. The second problem , my magic mirror fires electron.js error when I try to create file. I’m new on these, how can i use mm.sh for create&locate remotefile.json under compliments folder ?
            sdetweil @emrah_asl
            @emrah_asl said in Updating Compliments using a spreadsheet:
            1. my code in node_helper.js (under compliments folder) are creating file on root normally when you start mm with npm start
            don’t make this node_helper.js as MM has a special use for that…
            make it createCompliments.js
            then the best thing is use the full path for the file
                 fs.writeFile("/home/pi/MagicMirror/modules/default/compliments/remotefile.json", compliments, function(err) {
            how do you start MM?
            pm2 start 0 (and it starts on boot too…) If you used the automated install script u would have been prompted to set this up.
            (if u want to add it now, you can run the fixuppm2.sh script from here
            just one line to copy/paste
            now, if you use pm2, it launches MM by using the installers/mm.sh script. you can add your
            node modules/default/compliments/createCompliments.js
            to the mm.sh and all will continue as normal.
            i don’t understand this.
            npm start fires electron.js
            npm reads the package,json file and looks for the command requested
            	"scripts": {
            		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
            the ‘start’ command executes that line.
