Navigation
    • Search
    How to clear cache?
    Development
    • Sean
      Sean Module Developer last edited by Sean
      I’m making a module which operates several images. After finishing development on my Mac then testing on RPi, I found something.
      I’ve found cached images are consuming too much RAM of RPI.
      Just showing dozens of x00kb images takes memory consumption around 20%. I always remove HTML node for images after showing that. but memory is not returned. I guess it might be caused by cached data. Because, when I reload images previously already loaded and removed once, the memory doesn’t go down. Loading new images makes RAM goes down even after removed. So I doubt the cache issue.
      So I want to clear cache of Electron after my process is processed. How can I do that?
      I think there might be something like session.clearCache()…
      Sean 1 Reply Last reply Reply Quote 0
      • Sean
        Sean Module Developer @Sean last edited by
        Nevermind.
        Electron seems to be able to control its cache automatically.
