    Automatic installation problems
    4 Posts 2 Posters 1.8k Views 2 Watching
      bsarrazin
      I have just received a pi 3. I have installed Raspbian with N00BS. I haven’t changed anything in the OS, not even the default username/password and I have installed MagicMirror using the automatic script.
      This is what I get after I reboot the pi:
      The command line is still on screen after reboot and MM doesn’t seem to be starting properly or be able to access anything.
      Help?
        bsarrazin
        I have reinstalled Raspbian and instead of SSHing into the pi to run the command, I have run the command directly in the terminal in the UI of the pi. Seems to have fixed everything.
        • ? Offline
          [[global:former-user]] @bsarrazin
          @bsarrazin this is not related with topic, what is your display and how much price is?
            bsarrazin @Guest
            @Sean it’s an LG 34UC98-W
            it’s 34 inches, 21:9 aspect ratio and it’s curved
