    Todoist accesstoken
    9 Posts 5 Posters 5.2k Views 5 Watching
      robertweis56
      Hi, can anyone help me to understand where and how I get the accesstoken for Todoist.
      A step by step guide would be very helpful. Must I have a premium account?
      Thanks Robert
        sizer
        Did you figure it out??
        • N Offline
          ninjabreadman @sizer
          @sizer Go here:
          1. Create an app (e.g. “My Private MagicMirror”) in the developer’s console. If you don’t have a website, use example.com.
          2. Then with your client ID and secret, construct an OAuth query (with whatever scope your app will need) and visit in a browser.
          3. It will then redirect you to your app’s website with a code parameter. (If using example.com, it will fail to reach the site; just look at the address bar and find the code parameter.)
          4. Use thecode parameter to exchange for an access token (e.g. using curl):
          $ curl "https://todoist.com/oauth/access_token" \
              -d "client_id=0123456789abcdef" \
              -d "client_secret=secret" \
              -d "code=abcdef" \
              -d "redirect_uri=https://example.com"
          Problem with config or JavaScript? Copy/paste it into JSHint.
          Check out the detailed walkthroughs on install, config, modules, etc.
          zdenekZ 1 Reply Last reply Reply Quote 1
          • zdenekZ Offline
            zdenek @ninjabreadman
            @ninjabreadman great, but I’m lost. 1. is clear, but what to do now, where to construct OAuth (whetever is it)…?..
            thanks, Zdeněk
            • N Offline
              ninjabreadman @zdenek
              @zdenek Go here. Follow the instructions to create an OAuth string, that will look something like this:
              https://todoist.com/oauth/authorize?client_id=0123456789abcdef&scope=data:read,data:delete&state=secretstring
              zdenekZ 1 Reply Last reply Reply Quote 0
              • zdenekZ Offline
                @ninjabreadman thx. My steps:
                1. went to https://todoist.com/oauth/authorize?client_id=0123456789abcdef&scope=data:read,data:delete&state=secretstring
                  where I used my client_id and a “state” used "client_secret
                2. got
                  https://example.com/?state=client_secert&code=string_of_characters
                3. on MM from commandlind I run
                    -d "client_id=my_client_id" \
                    -d "client_secret=my_client_secret" \
                    -d "code=string_from_previous_step" \
                1. got answer
                  “access_token”:“another_string”,“token_type”:“Bearer”
                so, I guess, that “another_string” is the right think for the module = access_token, right?
                			module: 'MMM-Todoist',
                			position: 'top_center',	// This can be any of the regions. Best results in left or right regions.
                			//header: 'Todoist', // This is optional
                			config: { // See 'Configuration options' for more information.
                 		         	accessToken: 'axxxxxxxxxxb',
                				maximumEntries: 60,
                				updateInterval: 10*60*1000, // Update every 10 minutes
                				//projects: [ 166564794 ],
                				fade: false
                should be OK, but nothing :-(. Checked in browser:
                div id="module_10_MMM-Todoist" class="module MMM-Todoist MMM-Todoist">div class="module-content">table class="normal small light">/table>/div>/div>
                (removed < signs)
                in Console no Warnings, no Erros…
                any idea?
                • zdenekZ Offline
                  zdenek
                  i’m soooooooooo stupid sorry. I thougt, without define any ProjectID I’ll get ToDo of all Projects in my account. Nope. After add of at least one ID, it works…
                  sorry for annoying …
                  Zdeněk
                  • N Offline
                    @zdenek No problem, it happens to all of us. Glad to hear it’s working!
                      AgP42 Project Sponsor Module Developer
                      Hello all,
                      I also get so many trouble to make it work, but thanks to your help it is now ok ! :grinning_face:
                      So no need to create that incredibly complicated “OAuth string”, the use of the “Test token” works perfectly fine :
                      But… It is mandatory to define “projects” value in the config.js file.
                      As the default value is [] I also consider it as optional…:flushed_face:
                      With this value defined, everything is OK !
