    Need help for testing modules
    14 Posts 5 Posters 7.0k Views 5 Watching
    • ? Offline
      A Former User
      Hi, everyone.
      I’m building another(!) voice commander & assistant module for MagicMirror. Yes. I know already there are plenty of modules about it. Anyway, I think mine is somehow different, at least more fit for myself.
      It supports;
      • Google Assistant is embedded with gRpc. (not with python library). You don’t need to manage another daemon to use Google Assistant. It would start and stop with MagicMirror together. All features are controlled in MagicMirror.
      • snowboy hotwords detection is embedded. You can use 2 hotwords for Assistant mode and Command mode.
      • Speech-To-Text recognition engine is implemented. Currently google-cloud-speech API is used. I consider adding additional engines.
      • Pico2Wave is used for the response of command. I also consider adding other TTS solutions.
      • Module developers can add their command easily. It is really easy.
      • Ability(but limited) for foreign language besides English.
      sounds nice?
      But my brain is exhausted now. I am on the verge of hating development of this. hundreds of times for testing and debugging makes me disgusted. Thus I need your help.
      I think it’s better to open this before my interesting gone away. Bits of the help from people could make me gain concentration again. So please test this module and report issues on Github.
      What I want;
      • Check whether there be wrong instruction or information.
      • Check installation process. I doubt I might miss something else.
      • Check running. Report bug or problem.
      • And any suggestion will be welcomed.
      [card:eouia/MMM-Assistant]
      Read wiki first.
      Thanks in advance.
      • gauravsaccG Offline
        gauravsacc Module Developer
        @Sean said in Need help for testing modules:
        Nice @Sean ! I wrote a basic Google Assistant module https://github.com/gauravsacc/MMM-GoogleAssistant a while back and haven’t had time to implement all the features I wanted to. If you look at the readme you can tell i had the same ideas as you :) Happy to help test!
        • ? Offline
          A Former User @gauravsacc
          @gauravsacc Frankly, start of this module was stimulated by your module. ;)
          • T Offline
            TheOmran
            Running into the following errors installing the module.
            pi@raspberrypi:~/MagicMirror/modules/MMM-Assistant $ npm install --save-dev electron-rebuild && ./node_modules/.bin/electron-rebuild --pre-gyp-fix
            MMM-TelegramBot@1.0.0 /home/pi/MagicMirror/modules/MMM-Assistant
            └── electron-rebuild@1.6.0
            npm WARN MMM-TelegramBot@1.0.0 No repository field.
            npm WARN MMM-TelegramBot@1.0.0 No license field.
            ✖ Rebuild Failed
            An unhandled error occurred inside electron-rebuild
            gyp info it worked if it ends with ok
            gyp info using node-gyp@3.6.2
            gyp info using node@6.11.3 | linux | arm
            gyp http GET https://atom.io/download/electron/v1.7.8/iojs-v1.7.8.tar.gz
            gyp http 200 https://atom.io/download/electron/v1.7.8/iojs-v1.7.8.tar.gz
            gyp http GET https://atom.io/download/electron/v1.7.8/SHASUMS256.txt
            gyp http 200 https://atom.io/download/electron/v1.7.8/SHASUMS256.txt
            gyp info spawn /usr/bin/python2
            gyp info spawn args [ '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/node-gyp/gyp/gyp_main.py',
            gyp info spawn args   'binding.gyp',
            gyp info spawn args   '-f',
            gyp info spawn args   'make',
            gyp info spawn args   '-I',
            gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/snowboy/build/config.gypi',
            gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/node-gyp/addon.gypi',
            gyp info spawn args   '/home/pi/.electron-gyp/.node-gyp/iojs-1.7.8/common.gypi',
            gyp info spawn args   '-Dlibrary=shared_library',
            gyp info spawn args   '-Dvisibility=default',
            gyp info spawn args   '-Dnode_root_dir=/home/pi/.electron-gyp/.node-gyp/iojs-1.7.8',
            gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/node-gyp',
            gyp info spawn args   '-Dnode_lib_file=/home/pi/.electron-gyp/.node-gyp/iojs-1.7.8/(target_arch)/iojs.lib',
            gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/snowboy',
            gyp info spawn args   '-Dnode_engine=v8',
            gyp info spawn args   '--depth=.',
            gyp info spawn args   '--no-parallel',
            gyp info spawn args   '--generator-output',
            gyp info spawn args   'build',
            gyp info spawn args   '-Goutput_dir=.' ]
            gyp info spawn make
            gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
            make: Entering directory '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/snowboy/build'
              CXX(target) Release/obj.target/snowboy/swig/Node/snowboy.o
              SOLINK_MODULE(target) Release/obj.target/snowboy.node
            /usr/bin/ld: cannot find -lcblas
            collect2: error: ld returned 1 exit status
            snowboy.target.mk:130: recipe for target 'Release/obj.target/snowboy.node' failed
            make: Leaving directory '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/snowboy/build'
            make: *** [Release/obj.target/snowboy.node] Error 1
            gyp ERR! build error
            gyp ERR! stack Error: `make` failed with exit code: 2
            gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/node-gyp/lib/build.js:258:23)
            gyp ERR! stack     at emitTwo (events.js:106:13)
            gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
            gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
            gyp ERR! System Linux 4.9.41-v7+
            gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/.bin/node-gyp" "rebuild" "--target=1.7.8" "--arch=arm" "--dist-url=https://atom.io/download/electron" "--build-from-source" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/snowboy/lib/node/binding/Release/electron-v1.7-linux-arm" "--remote_path=./snowboy/v1.2.0/Release/" "--package_name=snowboy-v1.2.0-electron-v1.7-linux-arm.tar.gz" "--host=https://snowboy-release-node.s3-us-west-2.amazonaws.com"
            gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Assistant/node_modules/snowboy
            gyp ERR! node -v v6.11.3
            gyp ERR! node-gyp -v v3.6.2
            gyp ERR! not ok
            Failed with exit code: 1
            Error: gyp info it worked if it ends with ok
            gyp info spawn make
            gyp ERR! not ok
                at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/spawn-rx/lib/src/index.js:267:84)
                at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:238:16)
                at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:197:26)
                at Subscriber._error (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:128:26)
                at Subscriber.error (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:102:18)
                at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:128:26)
                at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:102:18)
                at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/spawn-rx/lib/src/index.js:241:65)
                at SafeSubscriber.__tryOrSetError (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:247:16)
                at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/rxjs/Subscriber.js:187:27)
            Solution was to (after going back and forth for hours) install the following.
            sudo apt-get install libatlas-base-dev
            Right now it seems to be installing, still at 2% but will update when it’s done!
            Oh, and great plugin man! :)
            • ? Offline
              A Former User @TheOmran
              @TheOmran thanks. Maybe i missed something in manual. I’ll check and add your result to wiki. Thanks again.
              • C Offline
                cxlwill
                I just starred your plugin while wandering at Github and go back to find the post at forum. I’m so excited that this plugin actually published with high level of completeness. You did a wonderful job!
                • ? Offline
                  A Former User @cxlwill
                  @cxlwill Thanks for your words. I hope I could find some nice East Asian Alternatives.
                  • T Offline
                    Txukie
                    I have been trying to make this work for a couple of days but I don’t seem to be able to achieve this. I have installed it correctly and add it to my screen, it does detect when I say “snowboy” but then it fails miserably.
                    This is the error it throws:
                    0|mm       | [ASSTNT] Conversation Error: Service unavailable.
                    0|mm       | Recording 16384 bytes
                    0|mm       | [ASSTNT] Conversation Error: { Error: Unknown Error.
                    0|mm       |     at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/node_modules/grpc/src/node/src/client.js:201:19)
                    0|mm       |     at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/node_modules/grpc/src/node/src/client.js:180:8)
                    0|mm       |     at /home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/node_modules/grpc/src/node/src/client.js:649:14
                    0|mm       |   code: 2,
                    0|mm       |   metadata: Metadata { _internal_repr: { 'content-disposition': [Object] } } }
                    This is the configuration file
                                      module: 'MMM-Assistant',
                                      position: 'bottom_left',
                                        assistant: {
                                          auth: {
                                            keyFilePath: "secret.json", //When you want to change the location of this file, set this.
                                            savedTokensPath: "resources/tokens.js" //When you want to change the location of this file, set this.
                                          audio: {
                                            encodingIn: "LINEAR16", //Ignore this. I think you don't need to change this.
                                            sampleRateOut: 16000 //Ignore this. I think you don't need to change this.
                                        snowboy: {
                                          models: [
                                              file: "resources/smart_mirror.pmdl",
                                              sensitivity: 0.5,
                                              hotwords : "MIRROR" //One of models should be "MIRROR"
                                              file: "resources/snowboy.umdl",
                                              sensitivity: 0.5,
                                              hotwords : "ASSISTANT" //One of models should be "ASSISTANT"
                                        record: {
                                          threshold: 0, //Ignore this. I think you don't need to change this.
                                          verbose:true, //true for checking recording status.
                                          recordProgram: 'rec', //You can use 'rec', 'sox'. But I recommend use 'arecord'.
                                          silence: 2.0 //Ignore this. I think you don't need to change this.
                                        stt: {
                                          auth: [{
                                            projectId: 'magicmirror-gassistant', //ProjectId from Google Console
                                            keyFilename: 'keyfile.json'
                                          }], //You can use multi accounts for saving money.
                                          request: {
                                            encoding: 'LINEAR16', //Ignore this. I think you don't need to change this.
                                            sampleRateHertz: 16000, //Ignore this. I think you don't need to change this.
                                            languageCode: 'en-US' //See https://cloud.google.com/speech/docs/languages
                                        speak: {
                                          useAlert: true, //If you want to show the text of speech, set this true. But It could be ignored by command of modules directly.
                                          language: 'en-US', //If you want to set the default language of speech of command result, set this.
                                        alias: [
                                            "help :command" : ["teach me :command", "what is :command"]
                                        ] // You can use aliases for difficult pronunciation or easy using.
                    Any help with this would be greatly appreciated
                    • ? Offline
                      A Former User @Txukie
                      @Txukie
                      Have you tried changing recordProgram to arecord?
                      • T Offline
                        Txukie
                        I have, it fails with another error:
                        [ASSTNT] Assistant Activated
                        Recording with sample rate 16000...
                        Recording 4000 bytes
                        End Recording: 431.071ms
                        Recording 12044 bytes
                        (node:10777) Warning: No such label 'End Recording' for console.timeEnd()
                        [ASSTNT] Conversation Error: { Error: Received RST_STREAM with error code 0
                            at /home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/node_modules/grpc/src/node/src/client.js:649:14 code: 13, metadata: Metadata { _internal_repr: {} } }
