    Trading module
    25 Posts 4 Posters 18.3k Views 3 Watching
    • P Offline
      plumcraft
      Hello,
      It could be nice to have a trading module which display like CAC40, EuroStock 50, instruments you’re following.
      I’ve tried to find a good public trading api but no luck for now…
      Anyone interested ?
      R 1 Reply Last reply Reply Quote 2
        ronny3050 Module Developer @plumcraft
        @plumcraft I am surprised this isn’t already there! I could take a look at this.
        • P Offline
          plumcraft
          Sure, let me know if you find something
            alexyak
            I’ve built a basic scrolling stocks ticker based on the Google APIs if you’re guys interested.
            • P Offline
              plumcraft
              Yes, will be happy to try it !
              thks
                alexyak
                Alright I’ve just published it. Enjoy: :)
                https://forum.magicmirror.builders/topic/496/stocks
                • P Offline
                  plumcraft
                  I got an error when trying your module :
                  stocks.js:110 GET http://finance.google.com/finance/info?client=ig&q=.DJI,MSFT,AAPL,GOOG,INTC,CICS,TSLA,FB getStocks @ stocks.js:110start @ stocks.js:19startModules @ loader.js:55(anonymous function) @ loader.js:40stylesheet.onload @ loader.js:190
                  192.168.0.31/:1 XMLHttpRequest cannot load http://finance.google.com/finance/info?client=ig&q=.DJI,MSFT,AAPL,GOOG,INTC,CICS,TSLA,FB. No ‘Access-Control-Allow-Origin’ header is present on the requested resource. Origin ‘http://192.168.0.31:8080’ is therefore not allowed access. The response had HTTP status code 500.
                  It might be a configuration issue on my side ?
                    alexyak @plumcraft
                    @plumcraft Hmm… that’s strange why you’re getting the CORS error. It works for me directly from the chromium… Where’re you running it from?
                    • P Offline
                      plumcraft
                      @alexyak : I’m testing it from a remote computer and directly on my RPI , and same issue…, don’t get it :(
                        alexyak
                        ok then the easiest solution would be to move this call to the node_helper…
                          alexyak @plumcraft
                          @plumcraft Ok, I found a bug in the code. Try to pull the latest and see if it runs for you.
                          • P Offline
                            plumcraft
                            @alexyak : thanks for your quick reply but no luck with the latest pull
                            • P Offline
                              plumcraft
                              I’ve tried to enable Cors which looks like the issue here but does not make any difference
                              (I’ve followed instructions on this website : http://jonathanmh.com/how-to-enable-cors-in-express-js-node-js/)
                                alexyak @plumcraft
                                @plumcraft could you please try the following:
                                Update the electron.js (it’s in the \js\ folder). Instead of:
                                mainWindow = new BrowserWindow({width: 800, height: 600,  fullscreen: true, autoHideMenuBar: true, darkTheme: true, webPreferences: {nodeIntegration: false}});
                                Replace it with:
                                mainWindow = new BrowserWindow({width: 800, height: 600,  fullscreen: true, autoHideMenuBar: true, darkTheme: true, webPreferences: {nodeIntegration: false, webSecurity: false}});
                                • P Offline
                                  plumcraft
                                  @alexyak,
                                  My bad Alexyak, it was working even if webSecurity was not set. It was an issue in my config.js, sorry for that.
                                  Your module is working only on the RPI, not inside a browser (webSecurity: false or true) but it’s not a big deal.
                                  I will try to find a solution
                                    alexyak @plumcraft
                                    @plumcraft the webSecurity flag will only work for running in the electron on RPI. Which web browser are you trying to run it in? It works for me for chrome and safari.
                                    • P Offline
                                      plumcraft
                                      @alexyak I’m using Google Chrome, does not work on Safari either.
                                        alexyak @plumcraft
                                        @plumcraft could you please make sure that you pulled the latest version of the MM from github?
                                        • P Offline
                                          plumcraft
                                          @alexyak Just tried it, i’m having the same issue :(
                                          • MichMichM Offline
                                            MichMich
                                            To prevent these kind of issues (and improve security) I suggest all cross server calls are done in the node helper. (That’s what the node helper is for)
