    Calendar Module problems update to Mirror to 2.1.3
    7 Posts 6 Posters 3.6k Views 6 Watching
    • K Offline
      knubbl
      HI,
      got a problem with calendar module showin more entries than configured
              timeFormat: "absolute",
              dateteFormat: "dd,DD.MMM,H.mm",
      	urgency: 0,
      	maximumEntries: 20,
      randomnoiseR 1 Reply Last reply Reply Quote 0
      • randomnoiseR Offline
        randomnoise @knubbl
        @knubbl I noticed mine was also displaying a lot more entries than it used to since I updated to 2.1.3.
        Do you have more than 1 calendar showing? I have 2 calendars so by setting the parameter to ‘5’ it shows a total of 10 now.
          mikehendley
          Yes, just updated mine and have probably 50 entries. Default was set to 10.
          -Mike
          • K Offline
            knubbl @randomnoise
            @randomnoise
            @randomnoise said in Calendar Module problems update to Mirror to 2.1.3:
            this might b a good hint. i have 3 calendars in total. will check this tonight if there is any multipilcation with the parameter and calendars
            • F Offline
              fabkai
              I have the same problem.
              I have four calendar and the entries are so many that they overlap the edge of the mirror.
              Additionally, the following error appears:
              Error: dates lower than Thu Jan 01 1970 00:00:00 GMT+0100 (CET) are not supported
              • zdenekZ Offline
                zdenek
                same here. 2 calendars, maxitems set to 15 in module conf so in total I want to have 15, but since new version, I’ve 15 from both, so 30 in total. I’ve to define maxItems to each calendar in its conf :-(
                • K Offline
                  kvicksson
                  Same here too with two calendars. Tried to set max entries to 5, but didn’t work for me, have at least 20 entries as I can see.
