    MMM-CalendarExt cant get the calendar to show
    23 Posts 8 Posters 15.7k Views 9 Watching
    • N Offline
      ninjabreadman @cruunnerr
      @cruunnerr Did you try the solution I suggested here? https://forum.magicmirror.builders/topic/6047/calendar-module-won-t-show-all-events/4
      Problem with config or JavaScript? Copy/paste it into JSHint.
      Check out the detailed walkthroughs on install, config, modules, etc.
      • cruunnerrC Offline
        cruunnerr
        Yeah i saw this and tried it. Works great :) Thank you
        • T Offline
          Turtle
          Hello my name is TL and I’m very very very new. I’m just trying to get something to show up and it seems that when I start the MagicMirror that I get all the other modules but the CalendarExt module. For some odd reason I have a feeling I’m missing something rather simple. Below is a copy of my config file and my npm start dev below:.
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			module: 'MMM-CalendarExt',
          			position: "top_left", //anywhere. It is not related to real position of view
          			config: { // Read below
          			  system:{
          			    show: ['daily'],
          			    locale: '', //when omitted, default value would be your system default locale by moment.js
          			    showEmptyView: 1,
          			    fullDayEventLocalize: 1,
          			    redrawInterval: 30*60*1000, //minimum 60000
          			    useProfileConfig: 0,
            			    startProfile: ''
          			  defaultView: {
          			    position: 'bottom_bar',
          			    positionOrder: -1,
          			    overflowRolling: 0,
          			    overflowHeight: 0,
          			    overflowDuration: 2,
          			    timeFormat: 'HH:mm',
          			    dateFormat: "MMM Do",
          		    	    fullDayEventDateFormat: "MMM Do",
          			    ellipsis: 0,
          			    limit:0,
          			    oneLineEvent:0,
          			    replaceTitle:[],
          			    classPattern:[],
          			    classPatternWhere:["title"],
          			    symbolPattern:[],
          			    symbolPatternWhere:["title"]
          			  views: {
                                       month: {
          				showWeeks: 1,
          				weeksTitle: 'weeks',
          				weeksFormat: 'wo',
          				weekdayFormat: 'dd',
          				titleFormat : 'D',
          				overTitleFormat : 'MMM D',
          				monthTitleFormat: "MMMM",
          			     weeks: {
          				showWeeks: 1,
          				weeksFormat: 'wo',
          				titleFormat : 'MMM D',
          				counts: 4,
          			     daily: {
          			        direction: 'row',
          			        counts: 5,
          			        titleFormat: "D",
          			        overTitleFormat: "MMM D",
          				subtitleFormat: "ddd",
          			     weekly: {
          			        direction: 'row',
          			    	counts: 4,
          			    	titleFormat: "wo",
          			    	overTitleFormat: "gggg wo",
          			    	subtitleFormat: "MMM Do",
          			     monthly: {
          			    	direction: 'row',
          			    	counts: 3,
          			    	titleFormat: "MMMM",
          			    	overTitleFormat: "YYYY MMM",
          				subtitleFormat: "YYYY",
          			     current: {
          				title: 'Current',
              				useRelative: 1
          			     upcoming: {
          				title: 'Upcoming',
              				useRelative: 1
          		          defaultCalendar: {
          			     profiles: [],
          				views: [],
          				symbol: "",
          				styleName: "",
          				replaceTitle:[],
          				classPattern: [],
          				classPatternWhere: ["title"],
          				symbolPattern: [],
          				symbolPatternWhere: ["title"],
          				maxEntries:50,
          				maxDays:180,
          				interval: 1800000,
          			      name: "Schooldays of John",
          				url: "https://school.com/schedule.ics",
          				auth: {
          				user:'john',
          				pass:'abcd1234',
          				method:'bearer'
          			      name: "US Holiday",
          				url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
          				profile: ['daddy'],
          				views: ['month', 'upcoming'],
          				styleName: "style1",
          				symbol: 'us@fi',
          				maxEntries: 50,
          				maxDays:365,
          				interval: 24*60*60*1000,
          			  profileConfigs: {
          			    "Tom" : {},
          			module: "compliments",
          			position: "lower_third"
          			module: "currentweather",
          				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
          				appid: "YOUR_OPENWEATHER_API_KEY"
          			module: "weatherforecast",
          			header: "Weather Forecast",
          				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "New York Times",
          				showSourceTitle: true,
          				showPublishDate: true
          Here is my npm start dev:
          pi@raspberrypi:~/MagicMirror $ npm start dev
          npm ERR! Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/dev/package.json'
          npm ERR!     at Error (native)
          npm ERR! If you need help, you may report this *entire* log,
          npm ERR! including the npm and node versions, at:
          npm ERR!
          npm ERR! System Linux 4.9.59-v7+
          npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
          npm ERR! cwd /home/pi/MagicMirror
          npm ERR! node -v v4.8.2
          npm ERR! npm -v 1.4.21
          npm ERR! path /home/pi/MagicMirror/node_modules/dev/package.json
          npm ERR! syscall open
          npm ERR! code ENOENT
          npm ERR! errno -2
          npm ERR!
          npm ERR! not ok code 0
          Thank you.
