    sendSocketNotification() fails
    Scheduled Pinned Locked Moved Solved Bug Hunt
    4 Posts 2 Posters 2.4k Views 2 Watching
      micsa
      I am trying to build a new module where the node_helper acts as an WebSocket server which it uses to listen events from external programs. Once data would be received from WS, it would send it to core module via sendSocketNotification(). However, this function always results an error when I try to call it (even with some dummy data).
      my node helper:
      var NodeHelper = require("node_helper");
      const SERVER_PORT = 9000;
      const WebSocket = require('ws');
      const wss = new WebSocket.Server({ port: SERVER_PORT });
      	// Subclass start method.
      	start: function() {
      		console.log("*******Starting module: " + this.name);
          console.log("Starting websocket server on port: " + SERVER_PORT);
          wss.on('connection', function connection(ws) {
            ws.on('message', function incoming(message) {
              //console.log('received: %s', message);
              console.log("Unparsed message: " + message);
              parsedMessage = JSON.parse(message);
              console.log("Parsed message: " + parsedMessage);
              //this.sendSocketNotification(message.messageType, message.payload);
              this.sendSocketNotification("FOOBAR", {key: "value"});
            ws.send('something');
          console.log("*******Started module: " + this.name);
      server console log:
      Ready to go! Please point your browser to: http://localhost:8080
      Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      Unparsed message: {"messageType":"speech_transcript","payload":{"alternatives":[],"isFinal":false,"stability":0.009999999776482582,"transcript":"the","confidence":0}}
      Parsed message: [object Object]
      TypeError: this.sendSocketNotification is not a function
          at WebSocket.incoming (/Users/makelm/node-projects/MagicMirror/modules/mami/node_helper.js:22:14)
          at emitTwo (events.js:106:13)
          at WebSocket.emit (events.js:191:7)
          at Receiver._receiver.onmessage (/Users/makelm/node-projects/MagicMirror/node_modules/ws/lib/WebSocket.js:146:54)
          at Receiver.dataMessage (/Users/makelm/node-projects/MagicMirror/node_modules/ws/lib/Receiver.js:389:14)
          at Receiver.getData (/Users/makelm/node-projects/MagicMirror/node_modules/ws/lib/Receiver.js:330:12)
          at Receiver.startLoop (/Users/makelm/node-projects/MagicMirror/node_modules/ws/lib/Receiver.js:165:16)
          at Receiver.add (/Users/makelm/node-projects/MagicMirror/node_modules/ws/lib/Receiver.js:139:10)
          at Socket._ultron.on (/Users/makelm/node-projects/MagicMirror/node_modules/ws/lib/WebSocket.js:142:22)
          at emitOne (events.js:96:13)
      • ? Offline
        A Former User @micsa
        @micsa
        Is here a problem?
        here, this doesn’t indicate your module, but function incoming(){...}
        So you can use these;
        1)
        var self =this;
                self.sendSocketNotification("FOOBAR", {key: "value"}
        or.
        2)
        wss.on('connection', (ws)=>{
              ws.on('message', (message)=> {
        I didn’t test it in real device, but you can understand what I mean.
        • ? Offline
          A Former User
          And If you use this callback in other scopes, you should bind proper object instance.
            micsa
            Thanks @Sean. Of course the problem relates to the this reference, which changes depending on the scope where it’s referenced. Thanks for pointing that out!
