Navigation
    • Search
    "moment npm package" causes black screen after npm start
    Troubleshooting
    • axellejamous
      axellejamous last edited by axellejamous
      Hello,
      I must be doing something very wrong.
      I followed the howchoo guide and did every step, except for 8.
      I also installed it manually since the automatic one wasn’t working for me.
      I’ve done all of my updates and upgrades and what-not but whenever I run
      DISPLAY=:0 npm start I get no errors, but the screen is just black.
      I’m using the provided config files with no modifications. Pulled from Master.
      //Update:
      I found out that this is the error that is causing it
      I basically get a ton of “Failed to load resource” errors and these cause this one to happen on a loop:
      I reinstalled moment, but the error still happens.
      • axellejamous
        This post is deleted!
        • axellejamous
          Solved the issue by simply running npm install in the vendor folder.
          Found thanks to this issue
          Thought I’d share the solution so maybe noobs like me can use it in the future.
