    Third Party Modules Don't Work Please Help
    21 Posts 5 Posters 11.9k Views 4 Watching
    • Z Offline
      zzaidi148 @cowboysdude
      @cowboysdude Very true. Thanks for the encouragement and help!
      • Z Offline
        zzaidi148 @Bob
        @Bob OMG thank you so much. Ok, so I pasted your working code with the api keys and everything worked and it booted up except the google maps traffic module. I’m right now working in landscape mode if that helps. When I started the mirror, it said that there were no helpers found for google maps. don’t know whether I missed something in the install of the module.
        • Z Offline
          @cowboysdude My module still won’t work. The rest of modules are showing except for the google maps traffic. Any idea?
          Z 1 Reply Last reply Reply Quote 0
          • Z Offline
            zzaidi148 @zzaidi148
            I even tried installing a stocks module by following a video of someone making their module and followed it to a tee but still didn’t get the module to work. It’s so frustrating!
            • Z Offline
              /* Magic Mirror Config Sample
               * MIT Licensed.
              var config = {
              	port: 8080,
              	language: "en",
              	timeFormat: 12,
              	units: "imperial",
              			module: "alert",
              			module: "updatenotification",
              			position: "top_bar",
              			module: "clock",
              			header: "US Holidays",
              						symbol: "calendar-check-o",
              						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
              			module: "compliments",
              			position: "lower_third",
              			module: "currentweather",
              				locationID: "4684888",  //ID from http://www.openweathermap.org/help/city_list.txt
              				appid: "e026fcbb673efea9ee3929a062c137ec",
              			module: "weatherforecast",
              			header: "Weather Forecast",
                  			module: 'MMM-Stock',
                  			position: 'lower_third',
                  			companies: ['MSFT', 'GOOG', 'ORCL', 'FB']
              			module: "newsfeed",
              			position: "bottom_bar",
              				feeds: [
              						title: "New York Times",
              				showSourceTitle: true,
              				showPublishDate: true
                          		module: 'MMM-GoogleMapsTraffic',
                              	key: 'AIzaSyBYRxkk4P4qB5ob506t1b5UHOBYVYntnfs',
                              	lat: 37.8262306,
                              	lng: -122.2920096,
                              	height: '300px',
                              	width: '300px',
              ? 2 Replies Last reply Reply Quote 0
              • ? Offline
                A Former User @zzaidi148
                @zzaidi148
                As I know, all the STOCK modules don’t work, because vendor API is blocked…
                Z 1 Reply Last reply Reply Quote 1
                • Z Offline
                  zzaidi148 @Guest
                  @Sean What about the first problem I had with the Google Maps Traffic Module not loading while the rest of the mirror started up? Is it because of where I placed it in the config file?
                  • ? Offline
                    @zzaidi148
                    I’m not familiar with that module. So I don’t know exactly.
                    As I see, there are some syntax errors in your module config.
                                    	   lat: 37.8262306,
                                    	   lng: -122.2920096,
                                    	   height: '300px',
                                    	   width: '300px',
                                            } // I think this bracket missed.
                          ] // And this also.
                    But I’m not sure this is the main reason of your problem.
                    • Z Offline
                      zzaidi148 @Guest
                      @Sean I made those changes, but my magic mirror is working but not displaying that module.
                      • ? Offline
                        @zzaidi148
                        Ok. There is no error but MMM-GoogleMapsTraffic is not shown, right?
                        You can try this
                        cd ~/MagicMirror
                        npm start dev
                        It will open your mirror with developer console something similar with this.
                        Then you can check there would be some errors(See the red circled X on the image) or warnings. You can find details in console tab.
                        And you can check your terminal log also.
                        If there is no suspicious point at all, but except that module everything is fine, Just that module has trouble you can not fix easily. Ask the developer directly on Github issue board.
                        • 2 / 3
