    Third Party Modules Don't Work Please Help
    21 Posts 5 Posters 13.1k Views 4 Watching
    • Z
      zzaidi148 @cowboysdude
      @cowboysdude I tried with only one module and it failed
      cowboysdudeC Mykle1M 2 Replies Last reply
      • cowboysdudeC
        cowboysdude Module Developer @zzaidi148
        @zzaidi148 It’s okay it’s how we learn :) We’ve all been there… if you try to get one module working and it doesn’t then post what you’ve done so we can help you…
        We don’t mind … like I said we ALL had to learn and there is no such thing as a stupid question ever. I personally don’t care if you have to ask the same question 1000 times… I or someone else will answer you.
        My education is in Education :) Just remember… whatever question you ask someone else may benefit from it too!
        Z 2 Replies Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @zzaidi148
          @zzaidi148 said in Third Party Modules Don’t Work Please Help:
          Your default config works, yes?
          Z 1 Reply Last reply
            Bob
            Ho hum, I got bored, so…
            @zzaidi148 here you go, below is your working code.
            As was said above, you needed to remove the // from var config, and the extra config section at the end. I also tidied up the code (putting spaces between modules to make them easier to read), and added some extra commas (because I tend to anyway) . You just need to replace the API keys with the correct ones and the code below will work.
            var config = {
            	port: 8080,
            	language: "en",
            	timeFormat: 12,
            	units: "imperial",
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar",
            			module: "clock",
            			header: "US Holidays",
            						symbol: "calendar-check-o",
            						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
            			module: "compliments",
            			position: "lower_third",
            			module: "currentweather",
            				locationID: "4684888",  //ID from http://www.openweathermap.org/help/city_list.txt
            				appid: "private",
            			module: "weatherforecast",
            			header: "Weather Forecast",
            				appid: "private",
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "New York Times",
            				showSourceTitle: true,
            				showPublishDate: true
                        module: 'MMM-GoogleMapsTraffic',
                            key: 'YOUR_KEY',
                            lat: 37.8262306,
                            lng: -122.2920096,
                            height: '300px',
                            width: '300px',
            • Z
              zzaidi148 @Mykle1
              @Mykle1 yes
              • Z
                @cowboysdude Very true. Thanks for the encouragement and help!
                • Z
                  zzaidi148 @Bob
                  @Bob OMG thank you so much. Ok, so I pasted your working code with the api keys and everything worked and it booted up except the google maps traffic module. I’m right now working in landscape mode if that helps. When I started the mirror, it said that there were no helpers found for google maps. don’t know whether I missed something in the install of the module.
                  • Z
                    @cowboysdude My module still won’t work. The rest of modules are showing except for the google maps traffic. Any idea?
                    • Z
                      zzaidi148 @zzaidi148
                      I even tried installing a stocks module by following a video of someone making their module and followed it to a tee but still didn’t get the module to work. It’s so frustrating!
                      • Z
                        /* Magic Mirror Config Sample
                         * MIT Licensed.
                        var config = {
                        	port: 8080,
                        	language: "en",
                        	timeFormat: 12,
                        	units: "imperial",
                        			module: "alert",
                        			module: "clock",
                        				appid: "e026fcbb673efea9ee3929a062c137ec",
                            			module: 'MMM-Stock',
                            			position: 'lower_third',
                            			companies: ['MSFT', 'GOOG', 'ORCL', 'FB']
                        			module: "newsfeed",
                        				feeds: [
                                        	key: 'AIzaSyBYRxkk4P4qB5ob506t1b5UHOBYVYntnfs',
                                        	lat: 37.8262306,
                                        	lng: -122.2920096,
                                        	height: '300px',
                                        	width: '300px',
                        ? 2 Replies Last reply
                          A Former User @zzaidi148
                          @zzaidi148
                          As I know, all the STOCK modules don’t work, because vendor API is blocked…
                          • Z
                            zzaidi148 @Guest
                            @Sean What about the first problem I had with the Google Maps Traffic Module not loading while the rest of the mirror started up? Is it because of where I placed it in the config file?
                            ? 1 Reply Last reply
                              @zzaidi148
                              I’m not familiar with that module. So I don’t know exactly.
                              As I see, there are some syntax errors in your module config.
                                              	   lat: 37.8262306,
                                              	   lng: -122.2920096,
                                              	   height: '300px',
                                              	   width: '300px',
                                                      } // I think this bracket missed.
                                    ] // And this also.
                              But I’m not sure this is the main reason of your problem.
                              • Z
                                zzaidi148 @Guest
                                @Sean I made those changes, but my magic mirror is working but not displaying that module.
                                  @zzaidi148
                                  Ok. There is no error but MMM-GoogleMapsTraffic is not shown, right?
                                  You can try this
                                  npm start dev
                                  It will open your mirror with developer console something similar with this.
                                  Then you can check there would be some errors(See the red circled X on the image) or warnings. You can find details in console tab.
                                  And you can check your terminal log also.
                                  If there is no suspicious point at all, but except that module everything is fine, Just that module has trouble you can not fix easily. Ask the developer directly on Github issue board.
                                    >             		config: {
                                    >                 	lat: 37.8262306,
                                    >                 	lng: -122.2920096,
                                    >                 	height: '300px',
                                    >                 	width: '300px',
                                    I’ve found what is wrong.
                                    you should set position of this module.
                                    position: 'top_left', //this is missed.
                                    manual of @vicmora has missed this.
                                    Reply Quote 2
