    Third Party Modules Don't Work Please Help
    21 Posts 5 Posters 11.9k Views 4 Watching
      https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
      • cowboysdudeC Offline
        Rule of thumb for new guys/gals…
        Add one module at a time… if your config works then back it up before adding something else that way you have a working config… always :)
        Z 1 Reply Last reply Reply Quote 3
          Bob
          remove the second instance of
          var config = (
          module : [
          at the bottom of the file
          • Z Offline
            zzaidi148 @cowboysdude
            @cowboysdude I tried with only one module and it failed
            cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 0
              cowboysdude Module Developer @zzaidi148
              @zzaidi148 It’s okay it’s how we learn :) We’ve all been there… if you try to get one module working and it doesn’t then post what you’ve done so we can help you…
              We don’t mind … like I said we ALL had to learn and there is no such thing as a stupid question ever. I personally don’t care if you have to ask the same question 1000 times… I or someone else will answer you.
              My education is in Education :) Just remember… whatever question you ask someone else may benefit from it too!
              Z 2 Replies Last reply Reply Quote 0
                Mykle1 Project Sponsor Module Developer @zzaidi148
                @zzaidi148 said in Third Party Modules Don’t Work Please Help:
                Your default config works, yes?
                Z 1 Reply Last reply Reply Quote 0
                  Bob
                  Ho hum, I got bored, so…
                  @zzaidi148 here you go, below is your working code.
                  As was said above, you needed to remove the // from var config, and the extra config section at the end. I also tidied up the code (putting spaces between modules to make them easier to read), and added some extra commas (because I tend to anyway) . You just need to replace the API keys with the correct ones and the code below will work.
                  var config = {
                  	port: 8080,
                  	language: "en",
                  	timeFormat: 12,
                  	units: "imperial",
                  			module: "alert",
                  			module: "updatenotification",
                  			position: "top_bar",
                  			module: "clock",
                  			header: "US Holidays",
                  						symbol: "calendar-check-o",
                  						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                  			module: "compliments",
                  			position: "lower_third",
                  			module: "currentweather",
                  				locationID: "4684888",  //ID from http://www.openweathermap.org/help/city_list.txt
                  				appid: "private",
                  			module: "weatherforecast",
                  			header: "Weather Forecast",
                  				appid: "private",
                  			module: "newsfeed",
                  			position: "bottom_bar",
                  				feeds: [
                  						title: "New York Times",
                  				showSourceTitle: true,
                  				showPublishDate: true
                              module: 'MMM-GoogleMapsTraffic',
                                  key: 'YOUR_KEY',
                                  lat: 37.8262306,
                                  lng: -122.2920096,
                                  height: '300px',
                                  width: '300px',
                  • Z Offline
                    zzaidi148 @Mykle1
                    @Mykle1 yes
                    • Z Offline
                      @cowboysdude Very true. Thanks for the encouragement and help!
                      • Z Offline
                        zzaidi148 @Bob
                        @Bob OMG thank you so much. Ok, so I pasted your working code with the api keys and everything worked and it booted up except the google maps traffic module. I’m right now working in landscape mode if that helps. When I started the mirror, it said that there were no helpers found for google maps. don’t know whether I missed something in the install of the module.
