    Third Party Modules Don't Work Please Help
    21 Posts 5 Posters 13.1k Views 4 Watching
      Bob
      Ho hum, I got bored, so…
      @zzaidi148 here you go, below is your working code.
      As was said above, you needed to remove the // from var config, and the extra config section at the end. I also tidied up the code (putting spaces between modules to make them easier to read), and added some extra commas (because I tend to anyway) . You just need to replace the API keys with the correct ones and the code below will work.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar",
      			module: "clock",
      			header: "US Holidays",
      						symbol: "calendar-check-o",
      						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
      			module: "compliments",
      			position: "lower_third",
      			module: "currentweather",
      				locationID: "4684888",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "private",
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				appid: "private",
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
                  module: 'MMM-GoogleMapsTraffic',
                      key: 'YOUR_KEY',
                      lat: 37.8262306,
                      lng: -122.2920096,
                      height: '300px',
                      width: '300px',
      Z 1 Reply Last reply
      • Z
        zzaidi148 @Mykle1
        @Mykle1 yes
        • Z
          zzaidi148 @cowboysdude
          @cowboysdude Very true. Thanks for the encouragement and help!
          • Z
            zzaidi148 @Bob
            @Bob OMG thank you so much. Ok, so I pasted your working code with the api keys and everything worked and it booted up except the google maps traffic module. I’m right now working in landscape mode if that helps. When I started the mirror, it said that there were no helpers found for google maps. don’t know whether I missed something in the install of the module.
            • Z
              @cowboysdude My module still won’t work. The rest of modules are showing except for the google maps traffic. Any idea?
              • Z
                zzaidi148 @zzaidi148
                I even tried installing a stocks module by following a video of someone making their module and followed it to a tee but still didn’t get the module to work. It’s so frustrating!
                • Z
                  /* Magic Mirror Config Sample
                   * MIT Licensed.
                  var config = {
                  	port: 8080,
                  	language: "en",
                  	timeFormat: 12,
                  	units: "imperial",
                  			module: "alert",
                  			module: "clock",
                  				appid: "e026fcbb673efea9ee3929a062c137ec",
                      			module: 'MMM-Stock',
                      			position: 'lower_third',
                      			companies: ['MSFT', 'GOOG', 'ORCL', 'FB']
                  			module: "newsfeed",
                  				feeds: [
                                  	key: 'AIzaSyBYRxkk4P4qB5ob506t1b5UHOBYVYntnfs',
                                  	lat: 37.8262306,
                                  	lng: -122.2920096,
                                  	height: '300px',
                                  	width: '300px',
                  ? 2 Replies Last reply
                    A Former User @zzaidi148
                    @zzaidi148
                    As I know, all the STOCK modules don’t work, because vendor API is blocked…
                    • Z
                      zzaidi148 @Guest
                      @Sean What about the first problem I had with the Google Maps Traffic Module not loading while the rest of the mirror started up? Is it because of where I placed it in the config file?
                      ? 1 Reply Last reply
                        @zzaidi148
                        I’m not familiar with that module. So I don’t know exactly.
                        As I see, there are some syntax errors in your module config.
                                        	   lat: 37.8262306,
                                        	   lng: -122.2920096,
                                        	   height: '300px',
                                        	   width: '300px',
                                                } // I think this bracket missed.
                              ] // And this also.
                        But I’m not sure this is the main reason of your problem.
                        • Z
                          zzaidi148 @Guest
                          @Sean I made those changes, but my magic mirror is working but not displaying that module.
                            @zzaidi148
                            Ok. There is no error but MMM-GoogleMapsTraffic is not shown, right?
                            You can try this
                            npm start dev
                            It will open your mirror with developer console something similar with this.
                            Then you can check there would be some errors(See the red circled X on the image) or warnings. You can find details in console tab.
                            And you can check your terminal log also.
                            If there is no suspicious point at all, but except that module everything is fine, Just that module has trouble you can not fix easily. Ask the developer directly on Github issue board.
                              @zzaidi148 said in Third Party Modules Don’t Work Please Help:
                              >             		config: {
                              >                 	lat: 37.8262306,
                              >                 	lng: -122.2920096,
                              >                 	height: '300px',
                              >                 	width: '300px',
                              I’ve found what is wrong.
                              you should set position of this module.
                              position: 'top_left', //this is missed.
                              manual of @vicmora has missed this.
                              Reply Quote 2
