    MMM-Netatmo-Thermostat
    13 Posts 5 Posters 7.0k Views 5 Watching
    • O Offline
      overflOw11 @zdenek
      @zdenek said in MMM-Netatmo-Thermostat:
      do you plan to add more info from termostat (the time of next change based on the schedule, what is the “setpoint” temperature for actual schedule,…)
      Perfect !
      Yes you can change the color through the CSS file.
      And yes I plan to add more information about the thermostat in this plugin. For now, it’s a very simple module but it will be improved with time.
      When you ask me if you can change colors, I think about put colors of the module in configuration for example.
      Let me know if you think about something else.
      overflOw11
      zdenekZ 1 Reply Last reply Reply Quote 0
      • zdenekZ Offline
        zdenek @overflOw11
        @overflOw11 great. For me will be great, easy change color, also easy change of size of the circle, the align (seems to be to left, but I’ve it on the right side of screen) and definitely more infos. For example, I’ve the Thermostat in “away” state. Would be nice to see it on MM. Now I can see actual temp and state of thermostat, but without any idea, what shoudl be … for example-actual is 19 Celsius, Thermostat is off, but it’s ok, cause based on Schedule, temp should be not lower than 17 Celsius.
        I plan to buy and install Netatmo valves - do you plan to develop module also for this?
        but it’s great, thanks
        Zdeněk
        • O Offline
          overflOw11
          I just push an update to change easily the color of the circle.
          I will working on other features soon but for your information, I don’t have Netatmo valves so I don’t plan to develop module for this now.
          • zdenekZ Offline
            zdenek @overflOw11
            @overflOw11 excelent job. Is is possible to use HEX code of colour or just defined string?
            one more thing - hot change aligment? 0_1512747996642_c7e5ee5a-6c1f-49b3-9bde-1a54db7ffc4f-image.png
            as you can see, I’ve itn the right coloumn of screen and would be nice to have it aligned to center, or to right
            thanks, Zdeněk
              Smotx
              This post is deleted!
                Smotx
                Je ne sais pas pourquoi, mais ce module fait ‘bug’ le module ‘MMM-Pages’
                Lorsqu’on met en place ce module, ‘MMM-Pages’ ne change plus de page, ou change de page mais ne change pas l’affichage.
                Dommage.
                this module does not work with ‘MMM-Pages’.
                if this module is active ‘MMM-pages’ no longer changes page
                • ? Offline
                  A Former User
                  with MM 2.5 it doesn’t work to me.
                  Nothing is shown and no errors
                  • E Offline
                    enuzzo
                    • E Offline
                      enuzzo
