    MMM-Rest
    resturltemperature
    25 Posts 6 Posters 23.4k Views 7 Watching
    • T Offline
      Tuxdiver
      I just completed my first module: MMM-Rest (https://github.com/Tuxdiver/MMM-Rest)
      It calls a number of URLs and displays the values in a configurable table on the mirror. The URLs must return a single floating point or integer value, which will be formatted to a fixed number of digits and a custom suffix will be appended.
      I use it for displaying temperatures and other environmental values from a running OpenHAB server via its REST API.
      Screenshot
      Please have a look at it and feel free to give me some feedback!
      Best regards,
      Dirk
        balthaz
        Hello,
        In my config it stay in “loading mode” an idea ?
        my config :
        module: ‘MMM-Rest’,
        position: ‘bottom_right’, // This can be any of the regions.
        // Best results in one of the side regions like: top_left
        sections: [
        suffix: ‘°C’,
        digits: 1,
        url: ‘http://www.dirk-melchers.de/echo.php?text=22.54’,
        suffix: ‘%’,
        digits: 1,
        url: ‘http://www.dirk-melchers.de/echo.php?text=59.1’,
        suffix: ‘°C’,
        digits: 1,
        url: ‘http://www.dirk-melchers.de/echo.php?text=23.10’,
        suffix: ‘%’,
        digits: 1,
        url: ‘http://www.dirk-melchers.de/echo.php?text=62.1’,
        suffix: ‘°C’,
        digits: 1,
        url: ‘http://www.dirk-melchers.de/echo.php?text=-19.73’,
        output: [
        [‘Livingroom’,‘@1’,‘@2’],
        [‘Kitchen’,‘@3’,‘@4’],
        [‘Fridge’,‘@5’],
        • T Offline
          Tuxdiver @balthaz
          @balthaz Config looks good. Strange…
          I will add some debugging messages to the code later to make it easier to find the problem.
          • T Offline
            Tuxdiver @Tuxdiver
            @Tuxdiver said in MMM-Rest:
            OK, I added some debugging code. Please pull the current version and set
            debug: true;
            to the modules config section.
            I’m not sure, which is the best way to debug the version on the Raspi, but I think you could simply use a browser and connect to the Raspi. Maybe the console.log messages will be visible somewhere when using the electron app, but I don’t know where…
            strawberry 3.141S B 2 Replies Last reply Reply Quote 0
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @Tuxdiver
              @Tuxdiver you can open the console in electron with cmd+shift+I or start the mirror with npm start dev, then the console will be open from start
                balthaz @Tuxdiver
                @Tuxdiver
                I add debug mode, but where can i find the log ?
                I try a tcpdump, and they arre no connection to the url :
                pi@mirror:~/MagicMirror/modules/MMM-Rest $ sudo tcpdump |grep dirk
                tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
                listening on wlan0, link-type EN10MB (Ethernet), capture size 262144 bytes
                Stay in loading mode
                Thanks in advance
                • T Offline
                  Tuxdiver @balthaz
                  @balthaz Sorry for the delay… The problem is the same-origin-policy of JavaScript: you must not call any other server than the one, where the mirror is running.
                  I will change the module to use a node helper, but that might take some time.
                  T B 2 Replies Last reply Reply Quote 0
                  • T Offline
                    Tuxdiver @Tuxdiver
                    Module is updated on Github. Please try again. Now it uses a node_helper.js to fetch the remote data. Should solve the security “bug” of AJAX…
                      Jopyth Moderator
                      @Tuxdiver What kind of sensors are you using for this internally (your openHAB)?
                      Helpful sticky: How to troubleshoot
                        balthaz
                        Hello,
                        I am currently on vacation, I will try on my return.
                        • T Offline
                          Tuxdiver @Jopyth
                          @Jopyth said in MMM-Rest:
                          I have an ESP8266 / NodeMCU sensors in every room, which send temperate and humidity values via MQTT to the mirror running mosquitto MQTT broker and openHAB. The values from the openHAB - API are then displayed on the mirror using my module.
                            balthaz @Tuxdiver
                            @Tuxdiver Yes it’s working good now :)
                            Is it possible to display alphanumeric response?
                            • T Offline
                              Tuxdiver @balthaz
                              @balthaz Please have a look at the last version on Github :-)
                              Attention: it has an incompatible change of the config parameters - see README.md!
                              • 1 Offline
                                12wsx
                                Hello, i have problem with this module : saying Module Loading. I have installed newest version from github. It is clear instalation with no others module. How can I check where is the problem.
                                No need copy my config because it’s only one module copied from repository this module.
                                • T Offline
                                  Tuxdiver @12wsx
                                  @12wsx This could be a problem with the configured URLs: if the connection could not be made or the other side does not deliver any content, the “Module Loading” message does not disappear.
                                  Try setting the “debug” variable to true in the config and call the MM-Url with a normal browser (Chrome) and look at the development console for messages - maybe that could give you some hints.
                                  • K Offline
                                    konradwalsh
                                    Is it possible to create an in-line if statement to control the formatting?
                                    So, if the result, say @1 > 10 then color:red else color:green
                                    • T Offline
                                      Tuxdiver @konradwalsh
                                      @konradwalsh said in MMM-Rest:
                                      At a first look, I would suggest to change the “format:” parameter in “sections” to support something like that:
                                        { range:[0, 10],     format: ' span style="color: yellow"%d /span' },
                                        { range:[10, undef], format: 'span style="color: red"%d /span' },
                                        { format: 'span style="color: green"%d /span' },
                                      and to traverse the array and the first entry which matches wins. “undef” could mean “don’t care about this value” and an entry without range could be the “default” (which has to be the last entry).
                                      What is your opinion: could this solve your problem?
                                      Edit: HTML-Tags where removed by the forum system… Code above should be correct HTML of course
                                      • K Offline
                                        konradwalsh
                                        { range:[0, 10], format: ’ span style=“color: yellow”%d /span’ },
                                        { range:[10, undef], format: ‘span style=“color: red”%d /span’ },
                                        { format: ‘span style=“color: green”%d /span’ },
                                        Thanks for the prompt reply… Seems my PI has gone offline and I am at work… so I will try this later and report back
                                        • T Offline
                                          @konradwalsh just to make it clear: it’s not implemented right now, just a quick draft for discussion about that feature ;-)
                                          • K Offline
                                            konradwalsh @Tuxdiver
                                            @Tuxdiver
                                            yes of course
                                            I feel confident in implementing it myself and see what I come up with…
                                            I suppose it would be good to have a dynamic situation where it maybe a string.
                                            For example, I am displaying my Hot Water Level. The result will be Low - Good - High.
                                            So it maybe a case of comparing a string value and reacting… Low would be blue and high would be red
