    access filesystem
    4 Posts 3 Posters 1.5k Views 3 Watching
      MichaelTomTom
      Hello,
      I change an existing module (MMM-EasyPix) for my needs and therefor need to know all files in a directory. But when I insert a
      const fs = require( 'fs');
      at the beginning of the code so I could call
      fs.readdirSync()
      the whole module seems to crash
      Where is the error??
      Thanx for any help
      • L Offline
        Leobaillard
        I have the same problem. Someone has an idea?
        • N Offline
          ninjabreadman @Leobaillard
          @MichaelTomTom @Leobaillard Is it possible fs is already defined (as a constant)? Are you getting any error messages in the logs?
          Problem with config or JavaScript? Copy/paste it into JSHint.
          Check out the detailed walkthroughs on install, config, modules, etc.
          • L Offline
            Leobaillard
            As it turns out, I didn’t read enough: I had to use the node_helper to access the filesystem. Sorry for digging out the thread.
