MMM-Assistant Error Node module version
Hi !
I’m trying to setup the MMM-Assistant module. I followed the wiki install process but at the end I have an error in my console and I can’t launch the mirror.
Here is the error;
WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module ‘/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/speaker/build/Release/binding.node’
was compiled against a different Node.js version using
NODE_MODULE_VERSION 48. This version of Node.js requires
NODE_MODULE_VERSION 54. Please try re-compiling or re-installing
the module (for instance, usingnpm rebuildornpm install).I tried the npm rebuild, npm install, delete the node_modules folder and the npm install again, but I still have this error.
Thanks a lot for your help !
hi,
got the same error here today. did you figure out how to solve this?
