MagicMirror does not start at all
Help!
My MagicMirror has been working perfectly until today. Now it does not even start.Typing npm start results in nothing.
It just says:> magicmirror@2.1.3 start /home/pi/MagicMirror > sh run-start.shthe error logs say
0|mm | ERROR - MMM-Todoist: Error: connect ETIMEDOUT 13.33.76.244:443 0|mm | ERROR - MMM-Todoist: Error: connect ETIMEDOUT 13.33.76.244:443However these are probably old, since I have removed that module.
Starting the mirror with node serveronly works however, and I can view it in a browser.
I have no idea what is going on, and why it does not work.
Also I’m pretty new to this, so sorry if I did anything wrong -
@17saiiqb is that log maybe old? can you clear the logs and rerun the mirror? did you double chek that you removed the module from the config?
I kinda gave up, I’m just going to reinstall MagicMirror, and see if that fixes anything.
Can I mark a topic as closed by the way?
