    Failed at the magicmirror@2.2.2 start script 'sh-run-start.sh'
    41 Posts 9 Posters 36.3k Views 8 Watching
    • L Offline
      L_i_v_e
      I have stretch full (mm owner said lite not supported in a comment in this forum)
      I tried both automatic and manual installation, i tried with both node js 9.3.0 and the automatic node update from MM.
      How you installed It? What node version? Did u use -g after npm install?
      Btw i work only from SSH, to make It start i used pm2 before this new clean install
      I think my installer can’t install electron from what i read at installation fail
      • cruunnerrC Offline
        cruunnerr
        i did it exactly as wrote in this tutorial:
        https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
        only difference:
        i used Raspbian stretch lite and to disable the screensaver i used xscreensaver
        does need a little bit longer because u need to install the dependancies first, but it runs from the beginning without issues.
        but to be on the safety side, you can use raspbian jesse full as many users wrote about problems with stretch
          mafin
          Thank you for your answers.
          I am using stretch, see the cat /etc/os-release
          PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
          NAME="Raspbian GNU/Linux"
          VERSION_ID="9"
          VERSION="9 (stretch)"
          ID=raspbian
          ID_LIKE=debian
          HOME_URL="http://www.raspbian.org/"
          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
          I followed the steps in this guide Complete Setup Tutorial
          DISPLAY=:0 npm start can not solve the problem.
          I will try to install MM with the Guide on GitHub you posted and I will see that comes out.
          I will keep you updated.
          EDIT: So I followed the guide on GitHub and it works perfectly.
          Thank you very much for this suggestion.
          L 1 Reply Last reply Reply Quote 1
          • L Offline
            L_i_v_e
            Just tried again following this guide:
            so:
            sudo apt-get update
            sudo apt-get upgrade
            sudo apt-get install xinit xserver-xorg
            sudo apt-get install lxde-core
            sudo apt-get install lightdm
            sudo apt-get install git
            sudo apt-get install libxss1
            sudo apt-get install libnss3
            sudo apt-get install unclutter
            then once it said to use the autoinstaller i went with manual installation.
            After git clone i cd into MM and tried npm install… Ofc i didn’t work cause of missing npm so i tried with the simplest sudo apt-get install npm. After that i tried to verify node version with node -v but it did not gave any response. I tried anyway with sudo npm install into mm folder and it started… after a while it failed. This is the error i got, log attached.
            [0_1515066236979_npm-debug.log](Uploading 100%)
            npm WARN deprecated coffee-script@1.10.0: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
            npm WARN engine webdriverio@4.9.11: wanted: {"node":">= 4.8.5"} (current: {"node":"4.8.2","npm":"1.4.21"})
            > electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
            > node install.js
            sh: 1: node: not found
            npm WARN This failure might be due to the use of legacy binary "node"
            npm WARN For further explanations, please read
            /usr/share/doc/nodejs/README.Debian
            npm ERR! electron@1.4.15 postinstall: `node install.js`
            npm ERR! Exit status 127
            npm ERR!
            npm ERR! Failed at the electron@1.4.15 postinstall script.
            npm ERR! This is most likely a problem with the electron package,
            npm ERR! not with npm itself.
            npm ERR!     node install.js
            npm ERR! You can get their info via:
            npm ERR!     npm owner ls electron
            npm ERR! System Linux 4.9.59-v7+
            npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install"
            npm ERR! cwd /home/pi/MagicMirror
            npm ERR! node -v v4.8.2
            npm ERR! npm -v 1.4.21
            npm ERR! code ELIFECYCLE
            > uws@0.14.5 install /home/pi/MagicMirror/node_modules/socket.io/node_modules/engine.io/node_modules/uws
            > node-gyp rebuild > build_log.txt 2>&1 || exit 0
            > electron-chromedriver@1.7.1 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
            > node ./download-chromedriver.js
            npm ERR! tar.unpack untar error /root/.npm/webdriverio/4.9.11/package.tgz
            npm ERR!
            npm ERR! not ok code 0
            • L Offline
              L_i_v_e @mafin
              @mafin could you give me the exact command lint you used? In that guide the only thing said about the installation is to use the automatic installer…
              Using it i’m stuck here: (is it complete or stuck?)
              pi@raspberrypi:~ $ sudo bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
              $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
              $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
              $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
              $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
              $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
              $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
              \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                      \______/
              Updating packages ...
              Hit:1 http://mirrordirector.raspbian.org/raspbian stretch InRelease
              Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
              Reading package lists... Done
              Installing helper tools ...
              Building dependency tree
              Reading state information... Done
              build-essential is already the newest version (12.3).
              curl is already the newest version (7.52.1-5+deb9u3).
              git is already the newest version (1:2.11.0-3+deb9u2).
              unzip is already the newest version (6.0-21).
              wget is already the newest version (1.18-5+deb9u1).
              0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              Check current Node installation ...
              Node.js is not installed.
              Installing Node.js ...
              ## Installing the NodeSource Node.js v6.x repo...
              ## Populating apt-get cache...
              + apt-get update
              Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
              Hit:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease
              ## Confirming "stretch" is supported...
              + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_6.x/dists/stretch/Release'
              ## Adding the NodeSource signing key to your keyring...
              + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
              OK
              ## Creating apt sources list file for the NodeSource Node.js v6.x repo...
              + echo 'deb https://deb.nodesource.com/node_6.x stretch main' > /etc/apt/sources.list.d/nodesource.list
              + echo 'deb-src https://deb.nodesource.com/node_6.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
              ## Running `apt-get update` for you...
              + apt-get update
              Get:3 https://deb.nodesource.com/node_6.x stretch InRelease [4,635 B]
              Get:4 https://deb.nodesource.com/node_6.x stretch/main armhf Packages [1,006 B]
              Fetched 5,641 B in 2s (2,019 B/s)
              ## Run `apt-get install nodejs` (as root) to install Node.js v6.x and npm
              The following NEW packages will be installed:
                nodejs
              0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
              Need to get 8,790 kB of archives.
              After this operation, 41.1 MB of additional disk space will be used.
              Get:1 https://deb.nodesource.com/node_6.x stretch/main armhf nodejs armhf 6.12.3-1nodesource1 [8,790 kB]
              Fetched 8,790 kB in 11s (771 kB/s)
              Selecting previously unselected package nodejs.
              (Reading database ... 63014 files and directories currently installed.)
              Preparing to unpack .../nodejs_6.12.3-1nodesource1_armhf.deb ...
              Unpacking nodejs (6.12.3-1nodesource1) ...
              Setting up nodejs (6.12.3-1nodesource1) ...
              Processing triggers for man-db (2.7.6.1-2) ...
              Node.js installation Done!
              Cloning MagicMirror ...
              Cloning into 'MagicMirror'...
              remote: Counting objects: 8976, done.
              remote: Compressing objects: 100% (8/8), done.
              remote: Total 8976 (delta 3), reused 3 (delta 1), pack-reused 8967
              Receiving objects: 100% (8976/8976), 11.48 MiB | 1.09 MiB/s, done.
              Resolving deltas: 100% (5077/5077), done.
              Cloning MagicMirror Done!
              Installing dependencies ...
              npm WARN prefer global coffee-script@1.10.0 should be installed with -g
              npm WARN prefer global jsonlint@1.6.2 should be installed with -g
              > uws@0.14.5 install /root/MagicMirror/node_modules/uws
                cruunnerr
                No you are stuck ^^
                It is done. You can safely ignore warnings ;)
                Just copy and rename the sample config.js and start the mirror in the MagicMirror folder with using „npm Start“
                Or better use pm2
                Take a look at the great tutorials in the Forum.
                • L Offline
                  L_i_v_e @cruunnerr
                  @cruunnerr
                  I won’t be so sure…
                  ahahahaha
                  > magicmirror@2.2.2 start /home/pi/MagicMirror
                  > sh run-start.sh
                  /home/pi/MagicMirror/node_modules/electron/index.js:9
                    throw new Error('Electron failed to install correctly, please delete node_modules/' + path.basename(__dirname) + ' and try installing again')
                  Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                      at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
                      at Module._compile (module.js:570:32)
                      at Object.Module._extensions..js (module.js:579:10)
                      at Module.load (module.js:487:32)
                      at tryModuleLoad (module.js:446:12)
                      at Function.Module._load (module.js:438:3)
                      at Module.require (module.js:497:17)
                      at require (internal/module.js:20:19)
                      at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
                  npm ERR! Linux 4.9.59-v7+
                  npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                  npm ERR! node v6.12.3
                  npm ERR! npm  v3.10.10
                  npm ERR! magicmirror@2.2.2 start: `sh run-start.sh`
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
                  npm ERR! If you do, this is most likely a problem with the magicmirror package,
                  npm ERR!     sh run-start.sh
                  npm ERR!     npm bugs magicmirror
                  npm ERR! Or if that isn't available, you can get their info via:
                  npm ERR!     npm owner ls magicmirror
                    cruunnerr
                    didn’t expect that ^^
                    try going to your MagicMirror folder and type npm install electron@1.4.15
                    Maybe it will say, that this version is invalid.
                    Check the version here: /home/pi/MagicMirror/node_modules/electron/dist/version
                    or try it global sudo npm install -g electron@1.4.15
                    Question: Did u first install it manually and then with the automatic installer?
                    If so, did u delete your MagicMirror folder before using the automatic installer? If not, maybe this causes the error.
                    So try deleting the MagicMirror folder and then use the automatic installer again.
                    • L Offline
                      L_i_v_e
                      This post is deleted!
                      • L Offline
                        L_i_v_e @cruunnerr
                        @cruunnerr I went to jessie, tried again… it failed… reinstalled electron 3 times… still fails… always the same damn error…
                        i think i’m gonna build my own webpage with blackjack and hookers…
                        This is so incredible…
                        • 4 / 5
