Mirror stays black, nothing shown
So i mad the MM start after a lot of troubles (https://forum.magicmirror.builders/topic/6060/failed-at-the-magicmirror-2-2-2-start-script-sh-run-start-sh?page=1)
Now the problem is that the display/vncview stays black, no module shown. What can i do?
This is the console log from vnc~/MagicMirror $ npm start > magicmirror@2.2.2 start /home/pi/MagicMirror > sh run-start.sh Starting MagicMirror: v2.2.2 Loading config ... Loading module helpers ... No helper found for module: alert. Initializing new module helper ... Module helper loaded: updatenotification No helper found for module: clock. Initializing new module helper ... Module helper loaded: calendar No helper found for module: compliments. No helper found for module: currentweather. No helper found for module: weatherforecast. Initializing new module helper ... Module helper loaded: newsfeed All module helpers loaded. Starting server on port 8080 ... Server started ... Connecting socket for: updatenotification Connecting socket for: calendar Starting node helper for: calendar Connecting socket for: newsfeed Starting module: newsfeed Sockets connected & modules started ... Launching application.If i start without anty config i still get a black screen (compared to the old error message about the config file)
pi@raspberrypi:~/MagicMirror $ npm start > magicmirror@2.2.2 start /home/pi/MagicMirror > sh run-start.sh Starting MagicMirror: v2.2.2 Loading config ... WARNING! Could not find config file. Please create one. Starting with default configuration. Loading module helpers ... Initializing new module helper ... Module helper loaded: updatenotification No helper found for module: helloworld. All module helpers loaded. Starting server on port 8080 ... Server started ... Connecting socket for: updatenotification Sockets connected & modules started ... Launching application. -
Did you solve this issue, I am having the sameone.
i did
npm remove electron
npm install electron@1.7.9and my black screen is gone
