    Mirror stays black, nothing shown
    3 Posts 3 Posters 2.2k Views 5 Watching
    • L
      L_i_v_e
      So i mad the MM start after a lot of troubles (https://forum.magicmirror.builders/topic/6060/failed-at-the-magicmirror-2-2-2-start-script-sh-run-start-sh?page=1)
      Now the problem is that the display/vncview stays black, no module shown. What can i do?
      This is the console log from vnc
      ~/MagicMirror $ npm start
      > magicmirror@2.2.2 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.2.2
      Loading config ...
      Loading module helpers ...
      All module helpers loaded.
      Server started ...
      Starting module: newsfeed
      Launching application.
      If i start without anty config i still get a black screen (compared to the old error message about the config file)
      > sh run-start.sh
      Loading config ...
      WARNING! Could not find config file. Please create one. Starting with default configuration.
      No helper found for module: helloworld.
      Server started ...
      • idoodlerI
        idoodler Module Developer
        Did you solve this issue, I am having the sameone.
          i did
          npm remove electron
          npm install electron@1.7.9
          and my black screen is gone
