    MMM-Openhab
    58 Posts 18 Posters 38.4k Views 20 Watching
    • G Offline
      georgeashton02
      @tbbear when i add that line my code throws errors back at me? The code worked before regardless of what the name is…
      Any suggestions thanks
      tbbearT 1 Reply Last reply Reply Quote 0
      • tbbearT Offline
        tbbear Module Developer @georgeashton02
        @georgeashton02 As u can see the error is already marked… The name of your sitemap is MMM.sitemap so name it as MMM not ourhome
        Robert the Bear
        • G Offline
          georgeashton02 @tbbear
          @tbbear No I understand this, as i said the name even when changed doesnt make a difference for some reason
          • tbbearT Offline
            @georgeashton02 I dont know why your check tthows an error cause i typed your sitemap and i could run it without any problems in openhab2.5
            Robert the Bear
            • G Offline
              georgeashton02
              @tbbear That is very odd… what would you suggest i do?
              • tbbearT Offline
                @georgeashton02 use it!
                Robert the Bear
                • G Offline
                  georgeashton02
                  @tbbear I used this sitemap, put the url for my sitemap in the config script and put that config script into the magic mirror config file. What other steps do i need to complete. Im sorry very confused my bad… Thanks
                    Mrtrol2013 @tbbear
                    @tbbear Please tell me if I can use notifications to update my sitemaps in this module?
                    • tbbearT Offline
                      tbbear Module Developer @Mrtrol2013
                      @Mrtrol2013 No, the update is done by Openhab
                      Robert the Bear
                      • C Offline
                        cmachtel
                        Hi, This is great and works as described. But could you help me changing the html/css to make the module smaller and to remove the white square and the red Home icon? I Would like to have only the 3 lines with onformations.
                        Thank you
                        • 6
                        • 5 / 6
