    MMM-Openhab
    58 Posts 18 Posters 44.5k Views 20 Watching
    • tbbearT Offline
      tbbear Module Developer @johntech
      @johntech Nooo only insert this line
      sitemap ourhome label="Our Home" {
           Webview url="/static/MMM-View.html"
          Frame label="Today" {
              Text item=Date icon="calendar"
              Text item=Time  icon="time"
      Robert the Bear
      J G 2 Replies Last reply Reply Quote 0
      • Z Offline
        Zacki84
        HI,
        your module works perfect.
        I changed the css file a litte bit, but it didn´t refresh in MM.
        When I open the browser I cleard cache and see the new version. Do you know how to clear cache for this Module/MM?
        THX
          johntech @tbbear
          @tbbear
          Thank you for the reply! I have added the line as instructed in your reply. I also had to move the css file into the css directory in the html directory. Looking at the openHAB Basic UI on the screen the colors changed to black as set .
          In this screen, are you supposed to see the button layout as you displayed at the beginning of this article? There is the icon at the top of the screen showing that looks like something is missing.
          On the Magic Mirror screen, the only thing I see is a rectangle white bordered box on the screen.
          I seem to still be missing something.
          John
          tbbearT 1 Reply Last reply Reply Quote 0
          • tbbearT Offline
            @johntech Webview url=“/static/MMM-View.html” icon=none
            Robert the Bear
              johntech @tbbear
              @tbbear Ok that got rid of the icon on the openHAB web interface but I still get nothing on the Magic Mirror screen but the rectangular screen with a white border.
              What creates the buttons and labels on the Magic Mirror screen?
              • tbbearT Offline
                @johntech Please check again if u did all steps from my readme. looks like u have no fitting sitemap.
                Robert the Bear
                  johntech
                  @tbbear I found the problem!
                  	url: "http://wr-pi-openhab:8080/basicui/app?sitemap=MMM"   // url of your Openhab sitemap
                  I overlooked the fact the I needed to enter MY url to my openHAB program in the line above. Now everything works as it should!!
                  Thank you again for developing this module!!
                  John
                  • T Offline
                    tmcgregor
                    I have started building my own MagicMirror and would like to use your module to display who’s home based on phones connected to the wifi. I already have OpenHab set up with a sitemap showing who is home. After following your readme file, I now get a white box with nothing in it and chromium opens when MagicMirror does.
                    I made a copy of the sitemap and called it MMMOpenhab.sitemap and added your extra code. The sitemap works and I can access it. I get no errors when running npm start dev so MagicMirror can see the MMM-OpenHab module. I’m just not sure whats going wrong.
                    • lavolp3L Offline
                      lavolp3 Module Developer @tmcgregor
                      @tmcgregor Just FYI, you could also have that solution with the module MMM-NetworkScanner.
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                      • G Offline
                        georgeashton02 @tbbear
                        @tbbear Hi, What is the command to type into the terminal to download this module? Thank you
                          sdetweil @georgeashton02
                          @georgeashton02 where would you find this module?
                          • G Offline
                            georgeashton02 @sdetweil
                            @sdetweil I have found all of the information about it I just cannot find the information needed to install the module… Thanks
                              @georgeashton02 ok, how do you install modules in general?
                                @georgeashton02 https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1590679589616
                                • G Offline
                                  georgeashton02
                                  Yeh you need to clone all the files of the module then mostly npm install that module but i need the address to clone for the files
                                    @georgeashton02 said in MMM-Openhab:
                                    i’m not sure I understand that… you mean github?
                                    you know how to use search? google, or on github itself
                                    • G Offline
                                      georgeashton02
                                      @sdetweil Thanks i was being dumb, however i do have another problem any ideas why this is throwing errors at me?
                                      sitemap MMM label="MMM-Openhab"
                                      	        // Set for MMM-Openhab
                                      Frame label="TV"
                                          Switch item= BedroomTVPower
                                          Switch item= BedroomPauseTv
                                      Frame label="Lights"
                                          Colorpicker item= My_Room_Light_Colour
                                          Switch item= My_Room_Lights
                                      This was all working before i added the code that i was told to add by the MMM-openhab github page…
                                        @georgeashton02 where are those? In config?
                                        • G Offline
                                          georgeashton02
                                          @sdetweil Yes, That code if from my openhab .sitemap file
                                            @georgeashton02 ok, i dont know what that means
                                            • 2 / 3
