    MMM-Openhab
    58 Posts 18 Posters 46.2k Views 20 Watching
    • G
      georgeashton02 @tbbear
      @tbbear Hi, What is the command to type into the terminal to download this module? Thank you
        sdetweil @georgeashton02
        @georgeashton02 where would you find this module?
        • G
          georgeashton02 @sdetweil
          @sdetweil I have found all of the information about it I just cannot find the information needed to install the module… Thanks
            @georgeashton02 ok, how do you install modules in general?
              @georgeashton02 https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1590679589616
              • G
                georgeashton02
                Yeh you need to clone all the files of the module then mostly npm install that module but i need the address to clone for the files
                  @georgeashton02 said in MMM-Openhab:
                  i’m not sure I understand that… you mean github?
                  you know how to use search? google, or on github itself
                  • G
                    georgeashton02
                    @sdetweil Thanks i was being dumb, however i do have another problem any ideas why this is throwing errors at me?
                    sitemap MMM label="MMM-Openhab"
                    	        // Set for MMM-Openhab
                    	Webview url="/static/MMM-View.html"
                    Frame label="TV"
                        Switch item= BedroomTVPower
                        Switch item= BedroomPauseTv
                    Frame label="Lights"
                        Colorpicker item= My_Room_Light_Colour
                        Switch item= My_Room_Lights
                    This was all working before i added the code that i was told to add by the MMM-openhab github page…
                      @georgeashton02 where are those? In config?
                      • G
                        georgeashton02
                        @sdetweil Yes, That code if from my openhab .sitemap file
                          @georgeashton02 ok, i dont know what that means
                          • G
                            georgeashton02
                            @tbbear when i add that line my code throws errors back at me? The code worked before regardless of what the name is…
                            Any suggestions thanks
                            tbbearT 1 Reply Last reply Reply Quote 0
                            • tbbearT
                              tbbear Module Developer @georgeashton02
                              @georgeashton02 As u can see the error is already marked… The name of your sitemap is MMM.sitemap so name it as MMM not ourhome
                              Robert the Bear
                              • G
                                @tbbear No I understand this, as i said the name even when changed doesnt make a difference for some reason
                                • tbbearT
                                  @georgeashton02 I dont know why your check tthows an error cause i typed your sitemap and i could run it without any problems in openhab2.5
                                  Robert the Bear
                                  • G
                                    georgeashton02
                                    @tbbear That is very odd… what would you suggest i do?
                                    • tbbearT
                                      @georgeashton02 use it!
                                      Robert the Bear
                                      • G
                                        georgeashton02
                                        @tbbear I used this sitemap, put the url for my sitemap in the config script and put that config script into the magic mirror config file. What other steps do i need to complete. Im sorry very confused my bad… Thanks
                                          Mrtrol2013 @tbbear
                                          @tbbear Please tell me if I can use notifications to update my sitemaps in this module?
                                          • tbbearT
                                            tbbear Module Developer @Mrtrol2013
                                            @Mrtrol2013 No, the update is done by Openhab
                                            Robert the Bear
                                            • 2 / 3
