    MMM-Openhab
    58 Posts 18 Posters 47.2k Views 20 Watching
    • tbbearT
      tbbear Module Developer @Orakel
      @orakel U are using openhab2? The view file is in the directory …/html? I am sure its only a access problem.
      Robert the Bear
      • O
        Orakel
        hi tbbear.
        yes i am using openhab2 on a raspi2.
        the MMM-View.html is in the /html directory and the css dir is in the /html directory 2.
        both html file and the css directory are owner of the openhab user on the openhab2 server.
        wenn i open my MMM Sitemap within the PaperUI i can see my sitemap but at the top of it it says
        HTTP ERROR 404
        Problem accessing /static/MMM-View.html. Reason: Not Found
        i have to change to url in my config.js from http://… to http://… to see the Modul on the MagicMirror but i looks the same like in the paperUI view.
        white background… but i want it black with white fonts
        i tried to put the html file and the css directory into /icon/classic/ directory and changed the IP Adresse to localhost. i must do that for the Image Show in a sitemap. Now i have no errors viewing the Modul in the Mirror but it´s still white… like the sitemaps always shown in the paperUI from openhab2. But in the BasicUI view of the sitemap, if i move the mouse cursor to the top it appears that the localhost has refused the connection.
        i don´t know what i shoul do to get the modul working… still any ideas ?
        greetings
        tbbearT 1 Reply Last reply
        • tbbearT
          @orakel Can u try something: Replace the dir name ‘static’ in the files MMM-sitemap and in MMM-View with ‘html’
          Robert the Bear
          • O
            Orakel
            i did it before…it´s the same… i think i can´t use your module but i would like.
            is there anything else needed in openhab ? http binding ? web server ? anything else ?
            i tried to install another instance of MagicMirror on a WIndowsPC and its the same probleme here with the MMM-Openhab module so i think it´s an openhab problem
            • O
              Orakel
              after updating my openhab server your module works !!! i am so happy that it works.
              but there is still one little problem, when i am using your MMM-View.html and your MMM-Style.css.
              when i open my sitemap in the paperui it looks like it should. with one word awesome.
              but in my magicmirror its still white.
              but when i am using the mystyle.css and DarkTheme.html it works in the MagicMirror too.
              i dont know how to insert the code … but i found them in an openhab forum.
              • L
                LordMM
                i tried this module today.
                Where is the example sitemap file after installing the module ?
                Regards
                Jürgen
                • tbbearT
                  tbbear Module Developer @LordMM
                  @LordMM Hi Jürgen, looks like you speak german. Also das Beispiel ist in der readme mehr ist nicht nötig. Gruß Robert
                  Robert the Bear
                    johntech
                    I am running OH2 and just ran across your article about interfacing OH2 with MagicMirror. First of all thank you for this program. I’m just starting to use Magic Mirror.
                    Questions:
                    I have installed your code into Magic Mirror.
                    I have added your code to the MM config.js file
                    I have added the 2 files to my OH2 html directory.
                    Where I ran into trouble is in adding the code to my sitemap file.
                    You indicate that this added to the beginning of that code:
                    sitemap MMM label="MMM-Openhab"
                    	        // Set for MMM-Openhab
                    	Webview url="/static/MMM-View.html"
                    DO I replace my original code :
                    sitemap ourhome label="Our Home" {
                        Frame label="Today" {
                            Text item=Date icon="calendar"
                            Text item=Time  icon="time"
                    with your above code? If I do this then my OH2 will not start. Am I missing something? Thank you for any information!
                    John
                    • tbbearT
                      tbbear Module Developer @johntech
                      @johntech Nooo only insert this line
                      Robert the Bear
                      J G 2 Replies Last reply
                      • Z
                        Zacki84
                        HI,
                        your module works perfect.
                        I changed the css file a litte bit, but it didn´t refresh in MM.
                        When I open the browser I cleard cache and see the new version. Do you know how to clear cache for this Module/MM?
                        THX
                          johntech @tbbear
                          @tbbear
                          Thank you for the reply! I have added the line as instructed in your reply. I also had to move the css file into the css directory in the html directory. Looking at the openHAB Basic UI on the screen the colors changed to black as set .
                          In this screen, are you supposed to see the button layout as you displayed at the beginning of this article? There is the icon at the top of the screen showing that looks like something is missing.
                          On the Magic Mirror screen, the only thing I see is a rectangle white bordered box on the screen.
                          I seem to still be missing something.
                          John
                          • tbbearT
                            @johntech Webview url=“/static/MMM-View.html” icon=none
                            Robert the Bear
                            J 1 Reply Last reply
                              johntech @tbbear
                              @tbbear Ok that got rid of the icon on the openHAB web interface but I still get nothing on the Magic Mirror screen but the rectangular screen with a white border.
                              What creates the buttons and labels on the Magic Mirror screen?
                              • tbbearT
                                @johntech Please check again if u did all steps from my readme. looks like u have no fitting sitemap.
                                Robert the Bear
                                  johntech
                                  @tbbear I found the problem!
                                  	url: "http://wr-pi-openhab:8080/basicui/app?sitemap=MMM"   // url of your Openhab sitemap
                                  I overlooked the fact the I needed to enter MY url to my openHAB program in the line above. Now everything works as it should!!
                                  Thank you again for developing this module!!
                                  John
                                  • T
                                    tmcgregor
                                    I have started building my own MagicMirror and would like to use your module to display who’s home based on phones connected to the wifi. I already have OpenHab set up with a sitemap showing who is home. After following your readme file, I now get a white box with nothing in it and chromium opens when MagicMirror does.
                                    I made a copy of the sitemap and called it MMMOpenhab.sitemap and added your extra code. The sitemap works and I can access it. I get no errors when running npm start dev so MagicMirror can see the MMM-OpenHab module. I’m just not sure whats going wrong.
                                    lavolp3L 1 Reply Last reply
                                    • lavolp3L
                                      lavolp3 Module Developer @tmcgregor
                                      @tmcgregor Just FYI, you could also have that solution with the module MMM-NetworkScanner.
                                      How to troubleshoot modules
                                      MMM-soccer v2, MMM-AVStock
                                      • G
                                        georgeashton02 @tbbear
                                        @tbbear Hi, What is the command to type into the terminal to download this module? Thank you
                                          sdetweil @georgeashton02
                                          @georgeashton02 where would you find this module?
                                          G 1 Reply Last reply
                                          • G
                                            georgeashton02 @sdetweil
                                            @sdetweil I have found all of the information about it I just cannot find the information needed to install the module… Thanks
                                            S 2 Replies Last reply
                                            • 2 / 3
