    MMM-Openhab
    58 Posts 18 Posters 46.2k Views 20 Watching
    • cruunnerrC
      cruunnerr
      Even if i have no OpenHAB System running, your module looks great :)
      keep it up :) Well done
      cowboysdudeC 1 Reply Last reply Reply Quote 3
      • cowboysdudeC
        cowboysdude Module Developer @cruunnerr
        @cruunnerr I agree, this is amazing!!!
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @tbbear
          @tbbear
          This is your first module?
          I give up! It looks spectacular! Exceptionally well done, Robert.
          Congratulations!
          • P-Bo726P
            P-Bo726
            This module looks awesome. I’m new to openHAB, can you provide some more details about how to find my OpenHAB site map, edit site map and use the correct URL in config file? Also how is the response time on a RPI 3 with other modules running.
            tbbearT 1 Reply Last reply Reply Quote 0
            • tbbearT
              tbbear Module Developer @P-Bo726
              @P-Bo726 Hi, first of all u have to use openHAB, if u do then its easy to get ur sitemap into MM. The response time is under one second for ex. if u want to switch a light on or off.
              Robert the Bear
              • P-Bo726P
                P-Bo726
                For the URL is that my OpenHAB basicui, paperui, etc?
                • tbbearT
                  @P-Bo726 the url is the same u would call in your browser to get your basicui sitemap, only with (see in readme) a little modification, thats why i recomment to copy your basicui sitemap for ex. my def. sitemap is wr.sitemap and i did a copy to MMM.sitemap. In this add the extra line like said in the readme.
                  Robert the Bear
                  • O
                    Orakel
                    Im am using an openhabianpi Server on a Raspi2. Now i build a MagicMirror und i was happy to find your MMM Openhab Modul.
                    i configured everything like you told, but my Raspi didn´t find the MMM-View.html File. The Mirror shows the MMM-Sitemap but it has a white background und at the Top of the Module it shows … cant find MMM-View.html
                    do you have any ideas whats wrong ?
                    sorry for my not so good english its not my main language
                    greets
                    Orakel
                    • tbbearT
                      tbbear Module Developer @Orakel
                      @orakel Hi, thank’s for using my module. Please check if your MMM-View.html file is in the right directory and it has the same
                      owner and group that u use to run your MM.
                      Robert the Bear
                      • O
                        Orakel @tbbear
                        thx for your response
                        @tbbear so i have changed the owner and group from MMM-View.html from openhabian to openhab. same problem like before. you wrote that i have to change the owner and group like the owner i use on my MM, but i can´t change the owner to the owner pi.
                        is there any other idea, i really like to use your module.
                        greeting Orakel
                        tbbearT 2 Replies Last reply Reply Quote 0
                        • tbbearT
                          @orakel of course, i’m sorry i ment to change it to the same owner u use for openhab.
                          Robert the Bear
                          • tbbearT
                            @orakel U are using openhab2? The view file is in the directory …/html? I am sure its only a access problem.
                            Robert the Bear
                            • O
                              Orakel
                              hi tbbear.
                              yes i am using openhab2 on a raspi2.
                              the MMM-View.html is in the /html directory and the css dir is in the /html directory 2.
                              both html file and the css directory are owner of the openhab user on the openhab2 server.
                              wenn i open my MMM Sitemap within the PaperUI i can see my sitemap but at the top of it it says
                              HTTP ERROR 404
                              Problem accessing /static/MMM-View.html. Reason: Not Found
                              i have to change to url in my config.js from http://… to http://… to see the Modul on the MagicMirror but i looks the same like in the paperUI view.
                              white background… but i want it black with white fonts
                              i tried to put the html file and the css directory into /icon/classic/ directory and changed the IP Adresse to localhost. i must do that for the Image Show in a sitemap. Now i have no errors viewing the Modul in the Mirror but it´s still white… like the sitemaps always shown in the paperUI from openhab2. But in the BasicUI view of the sitemap, if i move the mouse cursor to the top it appears that the localhost has refused the connection.
                              i don´t know what i shoul do to get the modul working… still any ideas ?
                              greetings
                              • tbbearT
                                @orakel Can u try something: Replace the dir name ‘static’ in the files MMM-sitemap and in MMM-View with ‘html’
                                Robert the Bear
                                • O
                                  Orakel
                                  i did it before…it´s the same… i think i can´t use your module but i would like.
                                  is there anything else needed in openhab ? http binding ? web server ? anything else ?
                                  i tried to install another instance of MagicMirror on a WIndowsPC and its the same probleme here with the MMM-Openhab module so i think it´s an openhab problem
                                  • O
                                    Orakel
                                    after updating my openhab server your module works !!! i am so happy that it works.
                                    but there is still one little problem, when i am using your MMM-View.html and your MMM-Style.css.
                                    when i open my sitemap in the paperui it looks like it should. with one word awesome.
                                    but in my magicmirror its still white.
                                    but when i am using the mystyle.css and DarkTheme.html it works in the MagicMirror too.
                                    i dont know how to insert the code … but i found them in an openhab forum.
                                    • L
                                      LordMM
                                      i tried this module today.
                                      Where is the example sitemap file after installing the module ?
                                      Regards
                                      Jürgen
                                      • tbbearT
                                        tbbear Module Developer @LordMM
                                        @LordMM Hi Jürgen, looks like you speak german. Also das Beispiel ist in der readme mehr ist nicht nötig. Gruß Robert
                                        Robert the Bear
                                          johntech
                                          I am running OH2 and just ran across your article about interfacing OH2 with MagicMirror. First of all thank you for this program. I’m just starting to use Magic Mirror.
                                          Questions:
                                          I have installed your code into Magic Mirror.
                                          I have added your code to the MM config.js file
                                          I have added the 2 files to my OH2 html directory.
                                          Where I ran into trouble is in adding the code to my sitemap file.
                                          You indicate that this added to the beginning of that code:
                                          sitemap MMM label="MMM-Openhab"
                                          	        // Set for MMM-Openhab
                                          	Webview url="/static/MMM-View.html"
                                          DO I replace my original code :
                                          sitemap ourhome label="Our Home" {
                                              Frame label="Today" {
                                                  Text item=Date icon="calendar"
                                                  Text item=Time  icon="time"
                                          with your above code? If I do this then my OH2 will not start. Am I missing something? Thank you for any information!
                                          John
                                          • tbbearT
                                            tbbear Module Developer @johntech
                                            @johntech Nooo only insert this line
                                            Robert the Bear
                                            J G 2 Replies Last reply Reply Quote 0
