    MMM-Openhab
    58 Posts 18 Posters 47.2k Views 20 Watching
      johntech
      I am running OH2 and just ran across your article about interfacing OH2 with MagicMirror. First of all thank you for this program. I’m just starting to use Magic Mirror.
      Questions:
      I have installed your code into Magic Mirror.
      I have added your code to the MM config.js file
      I have added the 2 files to my OH2 html directory.
      Where I ran into trouble is in adding the code to my sitemap file.
      You indicate that this added to the beginning of that code:
      sitemap MMM label="MMM-Openhab"
      	        // Set for MMM-Openhab
      	Webview url="/static/MMM-View.html"
      DO I replace my original code :
      sitemap ourhome label="Our Home" {
          Frame label="Today" {
              Text item=Date icon="calendar"
              Text item=Time  icon="time"
      with your above code? If I do this then my OH2 will not start. Am I missing something? Thank you for any information!
      John
      tbbearT 1 Reply Last reply
      • tbbearT
        tbbear Module Developer @johntech
        @johntech Nooo only insert this line
        Robert the Bear
        J G 2 Replies Last reply
        • Z
          Zacki84
          HI,
          your module works perfect.
          I changed the css file a litte bit, but it didn´t refresh in MM.
          When I open the browser I cleard cache and see the new version. Do you know how to clear cache for this Module/MM?
          THX
            johntech @tbbear
            @tbbear
            Thank you for the reply! I have added the line as instructed in your reply. I also had to move the css file into the css directory in the html directory. Looking at the openHAB Basic UI on the screen the colors changed to black as set .
            In this screen, are you supposed to see the button layout as you displayed at the beginning of this article? There is the icon at the top of the screen showing that looks like something is missing.
            On the Magic Mirror screen, the only thing I see is a rectangle white bordered box on the screen.
            I seem to still be missing something.
            John
            • tbbearT
              @johntech Webview url=“/static/MMM-View.html” icon=none
              Robert the Bear
              J 1 Reply Last reply
                johntech @tbbear
                @tbbear Ok that got rid of the icon on the openHAB web interface but I still get nothing on the Magic Mirror screen but the rectangular screen with a white border.
                What creates the buttons and labels on the Magic Mirror screen?
                • tbbearT
                  @johntech Please check again if u did all steps from my readme. looks like u have no fitting sitemap.
                  Robert the Bear
                    johntech
                    @tbbear I found the problem!
                    	url: "http://wr-pi-openhab:8080/basicui/app?sitemap=MMM"   // url of your Openhab sitemap
                    I overlooked the fact the I needed to enter MY url to my openHAB program in the line above. Now everything works as it should!!
                    Thank you again for developing this module!!
                    John
                    • T
                      tmcgregor
                      I have started building my own MagicMirror and would like to use your module to display who’s home based on phones connected to the wifi. I already have OpenHab set up with a sitemap showing who is home. After following your readme file, I now get a white box with nothing in it and chromium opens when MagicMirror does.
                      I made a copy of the sitemap and called it MMMOpenhab.sitemap and added your extra code. The sitemap works and I can access it. I get no errors when running npm start dev so MagicMirror can see the MMM-OpenHab module. I’m just not sure whats going wrong.
                      lavolp3L 1 Reply Last reply
                      • lavolp3L
                        lavolp3 Module Developer @tmcgregor
                        @tmcgregor Just FYI, you could also have that solution with the module MMM-NetworkScanner.
                        How to troubleshoot modules
                        MMM-soccer v2, MMM-AVStock
                        • G
                          georgeashton02 @tbbear
                          @tbbear Hi, What is the command to type into the terminal to download this module? Thank you
                            sdetweil @georgeashton02
                            @georgeashton02 where would you find this module?
                            G 1 Reply Last reply
                            • G
                              georgeashton02 @sdetweil
                              @sdetweil I have found all of the information about it I just cannot find the information needed to install the module… Thanks
                              S 2 Replies Last reply
                                @georgeashton02 ok, how do you install modules in general?
                                  @georgeashton02 https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1590679589616
                                  • G
                                    georgeashton02
                                    Yeh you need to clone all the files of the module then mostly npm install that module but i need the address to clone for the files
                                      @georgeashton02 said in MMM-Openhab:
                                      i’m not sure I understand that… you mean github?
                                      you know how to use search? google, or on github itself
                                      • G
                                        georgeashton02
                                        @sdetweil Thanks i was being dumb, however i do have another problem any ideas why this is throwing errors at me?
                                        Frame label="TV"
                                            Switch item= BedroomTVPower
                                            Switch item= BedroomPauseTv
                                        Frame label="Lights"
                                            Colorpicker item= My_Room_Light_Colour
                                            Switch item= My_Room_Lights
                                        This was all working before i added the code that i was told to add by the MMM-openhab github page…
                                          @georgeashton02 where are those? In config?
                                          • G
                                            georgeashton02
                                            @sdetweil Yes, That code if from my openhab .sitemap file
                                            • 2 / 3
