    MMM-Openhab
    58 Posts 18 Posters 47.2k Views 20 Watching
    • lavolp3L
      lavolp3 Module Developer @tmcgregor
      @tmcgregor Just FYI, you could also have that solution with the module MMM-NetworkScanner.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • G
        georgeashton02 @tbbear
        @tbbear Hi, What is the command to type into the terminal to download this module? Thank you
          sdetweil @georgeashton02
          @georgeashton02 where would you find this module?
          G 1 Reply Last reply
          • G
            georgeashton02 @sdetweil
            @sdetweil I have found all of the information about it I just cannot find the information needed to install the module… Thanks
            S 2 Replies Last reply
              @georgeashton02 ok, how do you install modules in general?
                @georgeashton02 https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1590679589616
                • G
                  georgeashton02
                  Yeh you need to clone all the files of the module then mostly npm install that module but i need the address to clone for the files
                    @georgeashton02 said in MMM-Openhab:
                    i’m not sure I understand that… you mean github?
                    you know how to use search? google, or on github itself
                    • G
                      georgeashton02
                      @sdetweil Thanks i was being dumb, however i do have another problem any ideas why this is throwing errors at me?
                      sitemap MMM label="MMM-Openhab"
                      	        // Set for MMM-Openhab
                      	Webview url="/static/MMM-View.html"
                      Frame label="TV"
                          Switch item= BedroomTVPower
                          Switch item= BedroomPauseTv
                      Frame label="Lights"
                          Colorpicker item= My_Room_Light_Colour
                          Switch item= My_Room_Lights
                      This was all working before i added the code that i was told to add by the MMM-openhab github page…
                        @georgeashton02 where are those? In config?
                        • G
                          georgeashton02
                          @sdetweil Yes, That code if from my openhab .sitemap file
                            @georgeashton02 ok, i dont know what that means
                            • G
                              georgeashton02
                              @tbbear when i add that line my code throws errors back at me? The code worked before regardless of what the name is…
                              Any suggestions thanks
                              tbbearT 1 Reply Last reply
                              • tbbearT
                                tbbear Module Developer @georgeashton02
                                @georgeashton02 As u can see the error is already marked… The name of your sitemap is MMM.sitemap so name it as MMM not ourhome
                                Robert the Bear
                                • G
                                  @tbbear No I understand this, as i said the name even when changed doesnt make a difference for some reason
                                  • tbbearT
                                    @georgeashton02 I dont know why your check tthows an error cause i typed your sitemap and i could run it without any problems in openhab2.5
                                    Robert the Bear
                                    • G
                                      georgeashton02
                                      @tbbear That is very odd… what would you suggest i do?
                                      • tbbearT
                                        @georgeashton02 use it!
                                        Robert the Bear
                                        M 1 Reply Last reply
                                        • G
                                          georgeashton02
                                          @tbbear I used this sitemap, put the url for my sitemap in the config script and put that config script into the magic mirror config file. What other steps do i need to complete. Im sorry very confused my bad… Thanks
                                            Mrtrol2013 @tbbear
                                            @tbbear Please tell me if I can use notifications to update my sitemaps in this module?
                                            • 2 / 3
