MMM-Openhab
@georgeashton02 said in MMM-Openhab:
but i need the address to clone for the files
i’m not sure I understand that… you mean github?
you know how to use search? google, or on github itself
@sdetweil Thanks i was being dumb, however i do have another problem any ideas why this is throwing errors at me?
sitemap MMM label="MMM-Openhab" { // Set for MMM-Openhab Webview url="/static/MMM-View.html" } Frame label="TV" { Switch item= BedroomTVPower Switch item= BedroomPauseTv } Frame label="Lights" { Colorpicker item= My_Room_Light_Colour Switch item= My_Room_Lights }This was all working before i added the code that i was told to add by the MMM-openhab github page…
@georgeashton02 where are those? In config?
@sdetweil Yes, That code if from my openhab .sitemap file
@georgeashton02 ok, i dont know what that means
@tbbear when i add that line my code throws errors back at me? The code worked before regardless of what the name is…
Any suggestions thanks
@georgeashton02 As u can see the error is already marked… The name of your sitemap is MMM.sitemap so name it as MMM not ourhome
@tbbear No I understand this, as i said the name even when changed doesnt make a difference for some reason
@georgeashton02 I dont know why your check tthows an error cause i typed your sitemap and i could run it without any problems in openhab2.5
@tbbear That is very odd… what would you suggest i do?
@georgeashton02 use it!
@tbbear I used this sitemap, put the url for my sitemap in the config script and put that config script into the magic mirror config file. What other steps do i need to complete. Im sorry very confused my bad… Thanks
@tbbear Please tell me if I can use notifications to update my sitemaps in this module?
@Mrtrol2013 No, the update is done by Openhab
Hi, This is great and works as described. But could you help me changing the html/css to make the module smaller and to remove the white square and the red Home icon? I Would like to have only the 3 lines with onformations.
Thank you
Great plugin! Is there a way to get rid of the frame around the container?
@t-moe Why yes there is you can do 1 of 2 ways:
First way:
Add this to your custom.css.MMM-Openhab .ifr { border: 0; }OR
In the modules directory where this module is open the css file and where you see this….MMM-Openhab .ifr { width: 400px; height: 680px; }Change it to this:
.MMM-Openhab .ifr { width: 400px; height: 680px; border: 0; }Should do it.
Hi all,
thanks for the module, it’s really a great addon for my MMs.
Since OH4.2 the theming is to be configured via the sitemap itself. Since I cannot use the mouse in electron, how could I change the settings to black and small arrangement?
Thanks in advance… -
Hi
Does anyone know how to change the font size in MMM-Openhab?
I have tried modifying every CSS and HTML style file and nothing seems to make a difference.
Thank you
@clakkentt no, but see the link in my signature below for how to use the developers window to see and adjust css
