    MMM-Openhab
    58 Posts 18 Posters 46.2k Views 20 Watching
    • tbbearT
      tbbear Module Developer @georgeashton02
      @georgeashton02 As u can see the error is already marked… The name of your sitemap is MMM.sitemap so name it as MMM not ourhome
      Robert the Bear
      • G
        georgeashton02 @tbbear
        @tbbear No I understand this, as i said the name even when changed doesnt make a difference for some reason
        tbbearT 1 Reply Last reply Reply Quote 0
        • tbbearT
          @georgeashton02 I dont know why your check tthows an error cause i typed your sitemap and i could run it without any problems in openhab2.5
          Robert the Bear
          • G
            georgeashton02
            @tbbear That is very odd… what would you suggest i do?
            • tbbearT
              @georgeashton02 use it!
              Robert the Bear
              • G
                georgeashton02
                @tbbear I used this sitemap, put the url for my sitemap in the config script and put that config script into the magic mirror config file. What other steps do i need to complete. Im sorry very confused my bad… Thanks
                  Mrtrol2013 @tbbear
                  @tbbear Please tell me if I can use notifications to update my sitemaps in this module?
                  • tbbearT
                    tbbear Module Developer @Mrtrol2013
                    @Mrtrol2013 No, the update is done by Openhab
                    Robert the Bear
                      cmachtel
                      Hi, This is great and works as described. But could you help me changing the html/css to make the module smaller and to remove the white square and the red Home icon? I Would like to have only the 3 lines with onformations.
                      Thank you
                      • T
                        T-Moe
                        Great plugin! Is there a way to get rid of the frame around the container?
                        • cowboysdudeC
                          cowboysdude Module Developer @T-Moe
                          @t-moe Why yes there is you can do 1 of 2 ways:
                          First way:
                          Add this to your custom.css
                          .MMM-Openhab .ifr {
                          	border: 0;
                          OR
                          In the modules directory where this module is open the css file and where you see this…
                          .MMM-Openhab .ifr {
                           	width: 400px;
                          	height: 680px;
                          Change it to this:
                          .MMM-Openhab .ifr {
                           	width: 400px;
                          	height: 680px;
                          	border: 0;
                          Should do it.
                          • F
                            falter
                            Hi all,
                            thanks for the module, it’s really a great addon for my MMs.
                            Since OH4.2 the theming is to be configured via the sitemap itself. Since I cannot use the mouse in electron, how could I change the settings to black and small arrangement?
                            Thanks in advance…
                            F 1 Reply Last reply Reply Quote 1
                              clakkentt
                              Hi
                              Does anyone know how to change the font size in MMM-Openhab?
                              I have tried modifying every CSS and HTML style file and nothing seems to make a difference.
                              Thank you
                                sdetweil @clakkentt
                                @clakkentt no, but see the link in my signature below for how to use the developers window to see and adjust css
                                  clakkentt @sdetweil
                                  @sdetweil Thank you for the guide. The properties of the elements I want to change seem to come from a material design style sheet .scss from the website hosting the webpage that is displayed in MagicMirror . Way above my level.
                                  I’ll have to live with the current font size
                                  Thanks again
                                    sdetweil @clakkentt
                                    @clakkentt yeh, if the page is presented in an iframe, you can’t fiddle with its styles anyhow…
                                    • F
                                      falter @falter
                                      said in MMM-Openhab:
                                      Hi all,
                                      Thanks in advance…
                                      I figured out that you indeed can use the mouse. Just add the code in custom.css, restart and apply with connected mouse, remove the code, restart, done :)
                                      html {
                                             cursor: unset;
                                      • 3 / 3
