    MMM-Openhab
    58 Posts 18 Posters 47.0k Views 20 Watching
    • G
      georgeashton02
      Yeh you need to clone all the files of the module then mostly npm install that module but i need the address to clone for the files
        sdetweil @georgeashton02
        @georgeashton02 said in MMM-Openhab:
        i’m not sure I understand that… you mean github?
        you know how to use search? google, or on github itself
        • G
          georgeashton02
          @sdetweil Thanks i was being dumb, however i do have another problem any ideas why this is throwing errors at me?
          sitemap MMM label="MMM-Openhab"
          	        // Set for MMM-Openhab
          	Webview url="/static/MMM-View.html"
          Frame label="TV"
              Switch item= BedroomTVPower
              Switch item= BedroomPauseTv
          Frame label="Lights"
              Colorpicker item= My_Room_Light_Colour
              Switch item= My_Room_Lights
          This was all working before i added the code that i was told to add by the MMM-openhab github page…
            @georgeashton02 where are those? In config?
            • G
              georgeashton02
              @sdetweil Yes, That code if from my openhab .sitemap file
                @georgeashton02 ok, i dont know what that means
                • G
                  georgeashton02
                  @tbbear when i add that line my code throws errors back at me? The code worked before regardless of what the name is…
                  Any suggestions thanks
                  tbbearT 1 Reply Last reply
                  • tbbearT
                    tbbear Module Developer @georgeashton02
                    @georgeashton02 As u can see the error is already marked… The name of your sitemap is MMM.sitemap so name it as MMM not ourhome
                    Robert the Bear
                    G 1 Reply Last reply
                    • G
                      georgeashton02 @tbbear
                      @tbbear No I understand this, as i said the name even when changed doesnt make a difference for some reason
                      • tbbearT
                        @georgeashton02 I dont know why your check tthows an error cause i typed your sitemap and i could run it without any problems in openhab2.5
                        Robert the Bear
                        • G
                          georgeashton02
                          @tbbear That is very odd… what would you suggest i do?
                          • tbbearT
                            @georgeashton02 use it!
                            Robert the Bear
                            M 1 Reply Last reply
                            • G
                              georgeashton02
                              @tbbear I used this sitemap, put the url for my sitemap in the config script and put that config script into the magic mirror config file. What other steps do i need to complete. Im sorry very confused my bad… Thanks
                                Mrtrol2013 @tbbear
                                @tbbear Please tell me if I can use notifications to update my sitemaps in this module?
                                • tbbearT
                                  tbbear Module Developer @Mrtrol2013
                                  @Mrtrol2013 No, the update is done by Openhab
                                  Robert the Bear
                                    cmachtel
                                    Hi, This is great and works as described. But could you help me changing the html/css to make the module smaller and to remove the white square and the red Home icon? I Would like to have only the 3 lines with onformations.
                                    Thank you
                                    • T
                                      T-Moe
                                      Great plugin! Is there a way to get rid of the frame around the container?
                                      • cowboysdudeC
                                        cowboysdude Module Developer @T-Moe
                                        @t-moe Why yes there is you can do 1 of 2 ways:
                                        First way:
                                        Add this to your custom.css
                                        .MMM-Openhab .ifr {
                                        	border: 0;
                                        OR
                                        In the modules directory where this module is open the css file and where you see this…
                                        .MMM-Openhab .ifr {
                                         	width: 400px;
                                        	height: 680px;
                                        Change it to this:
                                        .MMM-Openhab .ifr {
                                         	width: 400px;
                                        	height: 680px;
                                        	border: 0;
                                        Should do it.
                                        • F
                                          falter
                                          Hi all,
                                          thanks for the module, it’s really a great addon for my MMs.
                                          Since OH4.2 the theming is to be configured via the sitemap itself. Since I cannot use the mouse in electron, how could I change the settings to black and small arrangement?
                                          Thanks in advance…
                                          F 1 Reply Last reply
                                            clakkentt
                                            Hi
                                            Does anyone know how to change the font size in MMM-Openhab?
                                            I have tried modifying every CSS and HTML style file and nothing seems to make a difference.
                                            Thank you
                                            • 3 / 3
