    MMM-Openhab
    58 Posts 18 Posters 44.5k Views 20 Watching
    • G Offline
      georgeashton02
      @tbbear when i add that line my code throws errors back at me? The code worked before regardless of what the name is…
      Any suggestions thanks
      tbbearT 1 Reply Last reply Reply Quote 0
      • tbbearT Offline
        tbbear Module Developer @georgeashton02
        @georgeashton02 As u can see the error is already marked… The name of your sitemap is MMM.sitemap so name it as MMM not ourhome
        Robert the Bear
        • G Offline
          georgeashton02 @tbbear
          @tbbear No I understand this, as i said the name even when changed doesnt make a difference for some reason
          • tbbearT Offline
            @georgeashton02 I dont know why your check tthows an error cause i typed your sitemap and i could run it without any problems in openhab2.5
            Robert the Bear
            • G Offline
              georgeashton02
              @tbbear That is very odd… what would you suggest i do?
              • tbbearT Offline
                @georgeashton02 use it!
                Robert the Bear
                • G Offline
                  georgeashton02
                  @tbbear I used this sitemap, put the url for my sitemap in the config script and put that config script into the magic mirror config file. What other steps do i need to complete. Im sorry very confused my bad… Thanks
                    Mrtrol2013 @tbbear
                    @tbbear Please tell me if I can use notifications to update my sitemaps in this module?
                    • tbbearT Offline
                      tbbear Module Developer @Mrtrol2013
                      @Mrtrol2013 No, the update is done by Openhab
                      Robert the Bear
                      • C Offline
                        cmachtel
                        Hi, This is great and works as described. But could you help me changing the html/css to make the module smaller and to remove the white square and the red Home icon? I Would like to have only the 3 lines with onformations.
                        Thank you
                        • T Offline
                          T-Moe
                          Great plugin! Is there a way to get rid of the frame around the container?
                          • cowboysdudeC Offline
                            cowboysdude Module Developer @T-Moe
                            @t-moe Why yes there is you can do 1 of 2 ways:
                            First way:
                            Add this to your custom.css
                            .MMM-Openhab .ifr {
                            	border: 0;
                            OR
                            In the modules directory where this module is open the css file and where you see this…
                            .MMM-Openhab .ifr {
                             	width: 400px;
                            	height: 680px;
                            Change it to this:
                            .MMM-Openhab .ifr {
                             	width: 400px;
                            	height: 680px;
                            	border: 0;
                            Should do it.
                            • F Offline
                              falter
                              Hi all,
                              thanks for the module, it’s really a great addon for my MMs.
                              Since OH4.2 the theming is to be configured via the sitemap itself. Since I cannot use the mouse in electron, how could I change the settings to black and small arrangement?
                              Thanks in advance…
                              F 1 Reply Last reply Reply Quote 1
                              • C Offline
                                clakkentt
                                Hi
                                Does anyone know how to change the font size in MMM-Openhab?
                                I have tried modifying every CSS and HTML style file and nothing seems to make a difference.
                                Thank you
                                  sdetweil @clakkentt
                                  @clakkentt no, but see the link in my signature below for how to use the developers window to see and adjust css
                                  • C Offline
                                    clakkentt @sdetweil
                                    @sdetweil Thank you for the guide. The properties of the elements I want to change seem to come from a material design style sheet .scss from the website hosting the webpage that is displayed in MagicMirror . Way above my level.
                                    I’ll have to live with the current font size
                                    Thanks again
                                      sdetweil @clakkentt
                                      @clakkentt yeh, if the page is presented in an iframe, you can’t fiddle with its styles anyhow…
                                      • F Offline
                                        falter @falter
                                        said in MMM-Openhab:
                                        Hi all,
                                        Thanks in advance…
                                        I figured out that you indeed can use the mouse. Just add the code in custom.css, restart and apply with connected mouse, remove the code, restart, done :)
                                        html {
                                               cursor: unset;
                                        • 3 / 3
