    MMM-PIR-SENSOR not working
    17 Posts 9 Posters 13.0k Views 7 Watching
    • cruunnerrC Offline
      cruunnerr
      have u tried to delete the Pir Folder in your modules direction and start a simple new installation of the module?
      or just go into the MMM-PIR-Sensor folder and type npm install again?
        mab6435 @cruunnerr
        @cruunnerr I just deleted the entire module and downloaded it again, following the instructions directly from the page.
        To summarize, I know the sensor is working properly and connected to the right pin listed in the config file. I know nothing is wrong with the module i just downloaded it from github. I’ve posted the exact copy of my config file, no one seems to have a problem with that. What else could it be? For some reason the monitor wont shut off.
        Its a Benq monitor connected to the raspberry pi via an hdmi cord.
        Im not sure if this helps but when i type /opt/vc/bin/tvservice -s:
        state 0x12000a [HDMI CEA (16) RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
          cruunnerr
          i can switch off and on my display by simply typing sudo tvservice -o and sudo tvservice -p
            barnosch
            why are you using a MM module?
            This is not related to the mirror itself. Use @cowboysdude (how funny is that in this context ;) ) script.
            You can find it in his github respository. By the way, this dude creates really cool stuff, so its worth to have a closer look to it.
            If your PIR is cabled well, it should work easily.
              davide
              mba , I had the same issue but only because you have to force one detection, just the first time after you start magic mirror software. Then everything should be ok and working. So, after magic mirror is up and running, try to pass an hand in front of the sensor, then wait to see if it will turn off.
                sek_is_back
                I had the same problems and I dont know why. So I searched for another solution. Now it works perfect.
                I wrote one bash script for the power off and one for the power on.
                Script Power on:
                vcgencmd display_power 1
                Script Power off:
                vcgencmd display_power 0
                than I used this Pyhton for the PIR
                #!/usr/bin/env python
                import sys
                import time
                import RPi.GPIO as io
                import subprocess
                io.setmode(io.BCM)
                SHUTOFF_DELAY = 300  # seconds
                PIR_PIN = 25        # 22 on the board
                LED_PIN = 16        # 36 on the board
                def main():
                    io.setup(PIR_PIN, io.IN)
                    io.setup(LED_PIN, io.OUT)
                    turned_off = False
                    last_motion_time = time.time()
                    while True:
                        if io.input(PIR_PIN):
                            io.output(LED_PIN, io.LOW)
                            print ".",
                            sys.stdout.flush()
                            if turned_off:
                                turned_off = False
                                turn_on()
                        else:
                            if not turned_off and time.time() > (last_motion_time +
        SHUTOFF_DELAY):
                                turned_off = True
                                turn_off()
                            if not turned_off and time.time() > (last_motion_time + 1):
                                io.output(LED_PIN, io.HIGH)
                        time.sleep(.1)
                def turn_on():
                    subprocess.call("sh /home/pi/MagicMirror/pir/monitor_on.sh", shell=True)
                def turn_off():
                    subprocess.call("sh /home/pi/MagicMirror/pir/monitor_off.sh", shell=True)
                if __name__ == '__main__':
                    try:
                        main()
                    except KeyboardInterrupt:
                        io.cleanup()
                I tryed to upload but not enough privileges
                • O Offline
                  onis_uk @sek_is_back
                  @sek_is_back hi know this is old but where do you save the scripts to, to make them function?
