    Error in config file when adding modules, looking for another set of eyes
    5 Posts 4 Posters 1.9k Views 4 Watching
    • E Offline
      ejoy1220
      Hello, first off I am a hardware guy, coding is not something I regularly use, and I’m slowly slogging through this, it is intimidating.
      I am trying to add a Camera module with voice control to my Magic Mirror (RPi3), from https://github.com/alexyak/camera
      Here is what I have for a config file so far, but I am getting the error:
      “If you get this message while your config file is already created, your config file probably contains an error.”
      Here is my config.js contents:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check-o ",
      						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
      			module: "compliments",
      			position: "lower_third"
      			module: 'camera',
      			position: 'top_center',
      			config: selfieInterval: 3,  // Time interval in seconds before the photo will be taken.
      				emailConfig: {
      				service: 'GMail', // Email provider to use to send email with a photo.
      				auth: {
      					user: '', // Your email account
      					pass: ''        // Your password for email account
      			module: 'voicecontrol',
      			position: 'bottom_left',
      				models: [
      					keyword: "Show Camera",
      					description: "Say 'Show Camera' to display camera",
      					file: "showCamera.pmdl",
      					message: "SHOW_CAMERA"
      					keyword: "Hide Camera",
      					description: "Say 'Hide Camera' to hide camera",
      					file: "hideCamera.pmdl",
      					message: "HIDE_CAMERA"
      					keyword: "Selfie",
      					description: "Say 'Selfie' when camera is visible",
      					file: "selfie.pmdl",
      					message: "SELFIE"
      			module: "currentweather",
      				locationID: "4930956",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "My API"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				appid: "My API"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
      I had a difficult time editing this natively on the Pi, have copied the config.js files to a Windows machine and using NotePad++ to edit the file, the lines lining the code up help me immensely. Wish there was an easier workflow for me to use?
      randomnoiseR 1 Reply Last reply Reply Quote 0
        doubleT Module Developer
        your config is missing a closing bracket } in the config of the camera module. To be specific, it seems like the closing bracket of “auth:” is missing.
        And it also seems weird to me that after “config:” there is no object (in brackets), but that’s how the readme of the module shows the example configuration.
            module: "camera",
            position: "top_center",
            config: { // added this one, maybe missing/wrong in the example?
                emailConfig: {
                    service: "GMail", // Email provider to use to send email with a photo.
                    auth: {
                        user: "", // Your email account
                        pass: ""        // Your password for email account
                    } //  this one was missing
            } // added this one, maybe missing/wrong in the example?
        And also a closing bracket missing for the config: of the voicecontrol module:
            module: "voicecontrol",
            position: "bottom_left",
                    models: [
                        keyword: "Selfie",
                        message: "SELFIE"
        Some thing’s to consider: Use one sort of quotes throughout the file for strings of text. The config.js uses " while some module’s authors use '. Usually not a problem, but it’s cleaner to stick with one and helps minimize problems, for example when we look at this line from your config (which is not a problem but shows where it gets complicated):
        Some good ideas for people running into this to check their configs:
        • remove the last added module, run again, see if the problem is gone, if so, re-add the module and check brackets and commas, if not, re-add it, it wasn’t the source of the problem, check the next one.
        • or directly go through your file and check that every opening bracket has a matching closing bracket.
          Some text editors will highlight the closing bracket if you select the opening bracket be setting the cursor to it, or the other way round (Sublime Text does).
        • randomnoiseR Offline
          randomnoise @ejoy1220
          I installed samba on my pi & shared my home directory.
          You can then just browse to it from a windows machine & directly open your config.js, edit (notepad++ is the best choice imo) & then use putty to send a pm2 restart command.
          Google rpi samba as there’s plenty good info out there
          For bonus ease you could then access the mirror in a Web browser on the pc using for example 192.168.1.100:8080 (sub in your mm ip). You will first need to set the ‘interface’ parameter in your config.js to 0.0.0.0 and set the access list to include pc ip or subnet. This is how I do it so I don’t have to go & stand in front of the mirror while I’m making changes to it.
          • N Offline
            ninjabreadman
            Anyone having config.js issues can first copy/paste the module config (or whole thing) into JSHint (removing any API secrets or passwords). It will immediately draw attention to any syntax issues.
            Problem with config or JavaScript? Copy/paste it into JSHint.
            Check out the detailed walkthroughs on install, config, modules, etc.
            • E Offline
              ejoy1220
              Wow, thanks for these replies everyone.
              Blows my mind how it was just basically missing just a few “small,” to me, pieces.
              Hard to pick those out, need to step my game up and hit up CodeAcademy.
              JSHint is perfect! That will help me out a TON!
              And @RandomNoise, thank you for that idea, going to make it MUCH easier to browse and modify files that way!
              You guys rock thanks, what a great community
