    Two instances running if using pm2 start script
    2 Posts 2 Posters 1.7k Views 2 Watching
    • V Offline
      veitk
      Hi, i installed and everything looks good. I wrote the mm.sh to get pm2 to autostart.
      ~/MagicMirror
      DISPLAY=:0 npm start
      now i minimized with STRG+M and realized that there are two instances running.
      if i type pm2 stop mm it stops the second instance, and i see another which is called MagicMirror.
      How do i get it to start only one and still have the restart feature?
      i will delete the mm.sh now but i don’t think this is the way i want it?
      • N Offline
        ninjabreadman @veitk
        Hi @veitk,
        Follow the instructions here: https://forum.magicmirror.builders/topic/6233/modules-not-always-loading/
        Problem with config or JavaScript? Copy/paste it into JSHint.
        Check out the detailed walkthroughs on install, config, modules, etc.
