    MMM-WatchDog
    12 Posts 7 Posters 12.4k Views 6 Watching
      rak
      Hello guys,
      I have mm running via PM2 already. I installed MMM-Watchdog. The gui crashed this night, but it did not restart. What did I do wrong?
      My PM2 looks like this …
      $ pm2 info MagicMirror
       Describing process with id 0 - name MagicMirror
      │ status            │ online                                   │
      │ name              │ MagicMirror                              │
      │ restarts          │ 0                                        │
      │ uptime            │ 37m                                      │
      │ script path       │ /home/pi/MagicMirror/installers/mm.sh    │
      │ script args       │ N/A                                      │
      │ error log path    │ /home/pi/.pm2/logs/MagicMirror-error.log │
      │ out log path      │ /home/pi/.pm2/logs/MagicMirror-out.log   │
      │ pid path          │ /home/pi/.pm2/pids/MagicMirror-0.pid     │
      │ interpreter       │ bash                                     │
      │ interpreter args  │ N/A                                      │
      │ script id         │ 0                                        │
      │ exec cwd          │ /home/pi                                 │
      │ exec mode         │ fork_mode                                │
      │ node.js version   │ N/A                                      │
      │ node env          │ N/A                                      │
      │ watch & reload    │ ✔                                        │
      │ unstable restarts │ 0                                        │
      │ created at        │ 2018-09-09T08:36:00.617Z                 │
       Revision control metadata
      │ revision control │ git                                            │
      │ remote url       │ https://github.com/MichMich/MagicMirror.git    │
      │ repository root  │ /home/pi/MagicMirror                           │
      │ last update      │ 2018-09-07T00:04:31.656Z                       │
      │ revision         │ 6aa156d95667b230264fd99c5df877b25759e710       │
      │ comment          │ Merge pull request #1343 from MichMich/develop │
      │ branch           │ master                                         │
        rak
        Found this. Can this b the reason it did not restart again?
        When your app stays up for less than min_uptime (1s by default) until max_restarts (15 by default) is exceeded, it will stop restarting. So the most likely explanation here is that your app keeps crashing over and over for some reason. Whenever it stays up for longer than min_uptime, max_restarts is reset, so the default values should work just fine.
