    MMM-WatchDog
    12 Posts 7 Posters 13.4k Views 6 Watching
    • cowboysdudeC Offline
      EXCELLENT!! Thank you!
        paviro
        Maybe this should be a default module?
        – The Doctor
        • MichMichM Offline
          MichMich
          In most cases this module should not be necessary and probably only causes confusion. I built it for a mirror running on macOS which gives some issues due to an webGL module which causes a buffer overflow after a few days of running. (Bug in WebGL).
          So this module is only there for edge cases. In most cases we just need to hunt down the bug causing the UI issue.
            paviro @MichMich
            @MichMich ah I see :)
            – The Doctor
            • K Offline
              KirAsh4 Moderator
              macOS is the edge case. :)
                Mr.Meeseeks
                Does it work on server only mode?
                CAAAAN DOO!👍
                • MichMichM Offline
                  MichMich
                  In that case only the server will be restarted, so that doesn’t make sense.
                    Mr.Meeseeks
                    Ha, ya that’s what I saw, it would shut down server. so I guess another reason why it’s not a default module unless it could detect if running in server mode.
                    CAAAAN DOO!👍
                    • F Offline
                      fox
                      Are there any issues with the newest update known?
                      I got it work again after removed the watchdog module
                      Issues With MMM-WatchDog known?
                      https://forum.magicmirror.builders/post/29827
                      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                        rak
                        Hello guys,
                        I have mm running via PM2 already. I installed MMM-Watchdog. The gui crashed this night, but it did not restart. What did I do wrong?
                        My PM2 looks like this …
                        $ pm2 info MagicMirror
                         Describing process with id 0 - name MagicMirror
                        │ status            │ online                                   │
                        │ name              │ MagicMirror                              │
                        │ restarts          │ 0                                        │
                        │ uptime            │ 37m                                      │
                        │ script path       │ /home/pi/MagicMirror/installers/mm.sh    │
                        │ script args       │ N/A                                      │
                        │ error log path    │ /home/pi/.pm2/logs/MagicMirror-error.log │
                        │ out log path      │ /home/pi/.pm2/logs/MagicMirror-out.log   │
                        │ pid path          │ /home/pi/.pm2/pids/MagicMirror-0.pid     │
                        │ interpreter       │ bash                                     │
                        │ interpreter args  │ N/A                                      │
                        │ script id         │ 0                                        │
                        │ exec cwd          │ /home/pi                                 │
                        │ exec mode         │ fork_mode                                │
                        │ node.js version   │ N/A                                      │
                        │ node env          │ N/A                                      │
                        │ watch & reload    │ ✔                                        │
                        │ unstable restarts │ 0                                        │
                        │ created at        │ 2018-09-09T08:36:00.617Z                 │
                         Revision control metadata
                        │ revision control │ git                                            │
                        │ remote url       │ https://github.com/MichMich/MagicMirror.git    │
                        │ repository root  │ /home/pi/MagicMirror                           │
                        │ last update      │ 2018-09-07T00:04:31.656Z                       │
                        │ revision         │ 6aa156d95667b230264fd99c5df877b25759e710       │
                        │ comment          │ Merge pull request #1343 from MichMich/develop │
                        │ branch           │ master                                         │
                          rak
                          Found this. Can this b the reason it did not restart again?
                          When your app stays up for less than min_uptime (1s by default) until max_restarts (15 by default) is exceeded, it will stop restarting. So the most likely explanation here is that your app keeps crashing over and over for some reason. Whenever it stays up for longer than min_uptime, max_restarts is reset, so the default values should work just fine.
